  #91
Old 06-15-2017, 10:23 PM
Vernon's Avatar
Vernon Vernon is offline
Originally Posted by metalbndr View Post
Very nice looking trailer. You will however change a couple of things after using it a bit. After gouging body parts on the tail lights, they will be moved to a vertical orientation, tucked in. The spare tire will be located on the side, front or rear of the fender. First to keep it out of the mud and gravel, second, sharp entry and exit from curbs and parking lots will scream and crunch. Onlookers will be crankin' their heads to see "WTF" was that. Just life's observations, the trailer is sweet.
(Quote) After gouging body parts on the tail lights, they will be moved to a vertical orientation, tucked in. I stay well with end the lines and if someone wants to join my party than it's there loss on body parts.
(Quote) The spare tire will be located on the side, front or rear of the fender. First to keep it out of the mud and gravel, second, sharp entry and exit from curbs and parking lots will scream and crunch. Onlookers will be crankin' their heads to see "WTF" was that. The spare tire is under because any where else it's in the way. Far as the rack it's over 12" off the ground my hitch on my SUV will be a good 4" under the road way before rack touches.
(Quote) the trailer is sweet. Thank you.
Due to the lack of effort today Tomorrow has been canceled...................
  #92
Old 06-15-2017, 10:28 PM
Vernon's Avatar
Originally Posted by Barks View Post
Tip it on its side, install the nuts and save yourself the back ache.
I crawled under and did Maybe next time I'll take it to Dad's and use the Fork truck.
  #93
Old 06-15-2017, 10:30 PM
Vernon's Avatar
Originally Posted by LW Hiway View Post
I've never owned a trailer that had a protected license plate bracket assy.
As a plate has to be mounted on the horizontal and sitting under a light, the outside end of the plate is always exposed and usually gets beat the hell up, often breaking the tail light it's sitting under.
It seems that the width of the fenders and how the upright framing of the trailer does not allow the plate to be protected from/on it's outside edge
I have plans to increase it's life expectancy somewhat in the near future.
Hope to never lose my Tag. Everyone hangs them there way good luck on yours
  #94
Old 06-22-2017, 10:13 PM
metalbndr metalbndr is offline
I was thinking of your body parts. Loading or unloading, bit of a hurry, bend down, turn, sun gets in your eyes and **&*%^^$#@!!!!! metalbndr was right. Pm me when it happens, you don't have to tell everyone, LOL.
How does getting a tag for a homebuilt trailer work with the powers that be in your state ? Inspection, ser#
