Old 05-03-2006, 09:47 PM
Amalgam
Guest
Posts: n/a
Default Wiring an air compressor.
I have four wires coming from my panel. Red, Black, White, and uncovered. White comes from the neutral bus bar, Naked one at the ground bus bar. hot red and black from the breaker. Now, at the compressor I only have two screws that say line and one screw that looks it is ground, but I am not sure. if I put one hot wire in each scre line, and the ground wire to where I think it goes where am I suppose to conect the neutral?
I am attaching a picture of the compressor"s electrical panel
Name:	Circuit 002 copy.gif
Old 05-03-2006, 09:50 PM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
Cap the white off, the comp does not use a neutral wire.
Old 05-03-2006, 09:52 PM
ctardi's Avatar
ctardi ctardi is offline
Send a message via MSN to ctardi
Assuming that that is in fact a 220 volt compressor.
Old 05-03-2006, 10:26 PM
Sberry's Avatar
Good point, that hadnt occured to me when I answer. It pays to include the relevent info.
Old 05-04-2006, 09:25 AM
Amalgam
Guest
Posts: n/a
Thank you guys. It is indeed a 220V air compressor, I am sorry for omitting that piece of info.
Alfredo
