Old 11-21-2005, 05:06 PM
swampyankee swampyankee is offline
Default challenger car lift
I got a challenger twin beam car lift off a buddy for free. It doesn't have the hydrolics with it. Anyone know a good place that sells the parts I need in a package? I have looked in Northern and haven't found anything yet. thanks for the input.
Old 11-21-2005, 05:23 PM
rickairmedic's Avatar
SFT HVAC Guru
Swamp yankee ya might try the guys over at garage junkies one of the sights I frequent they are all about garage toys there and can prolly help ya out o the lift .
Rick
Old 11-21-2005, 05:25 PM
thanks for the tip
Old 11-21-2005, 05:27 PM
SFT HVAC Guru
No problem if knobody there has an answer for you there prolly isnt one then prolly a third of them have lifts and know where to get parts for them .
Rick
Old 11-21-2005, 05:42 PM
quadlinear's Avatar
quadlinear quadlinear is offline
I have a 4 post Backyard Buddy and a two post above ground. Both lifts use hydraulic cylinders and electric motor/pump/tank combination. I think Surplus center (on web) (www.surpluscenter.com) as well as Northern Hydraulics sells these motor pump combinations. Basically the whole motor/pump/valve/tank are included in a package. Can come in both 110 and 220 models. Considering the lift was free to you.... I think the added hydraulics of 3-4 hundred bucks is a real deal. I paid alot more for each of my lifts.
Alan
Quadlinear
corner of South West, Ohio
Old 11-21-2005, 07:05 PM
wayne64's Avatar
wayne64 wayne64 is offline
Default Thanks Quadlinear
Alan
My Hydra lifts pump is starting to make growling sounds and I may need a pump down the road. Here is my lift which I use for more of a work / welding table.
http://www.hydra-lift.com/ Mine is the model 710, and the best 4 grand I've ever spent.
Old 11-21-2005, 11:21 PM
quadlinear's Avatar
Wayne,
If it's beginning to growl, try to change the hyd fluid first. When oil gets dirty it will make the pump louder. Oil is the lifeblood of any hydraulic system. It's very imperitive to keep it clean.
Nice Lift you have there though. I use my Backyard buddy more for a dual level parking for the Porsches. The Two poster I have installed at my other shop where I have a taller ceiling and can actually walk underneath without crashing my head into something.
Alan
Quadlinear
Old 11-21-2005, 11:47 PM
Flashy avatar you got there, Alan.
