Old 01-04-2013, 05:36 PM
FabberMcGee FabberMcGee is offline
Nice job, looks good.
There are 2 or 3 welding shops in this town that build tanks as part of their business. They can have the crew can do that during slack times and keep them on the payroll. They have a simple flange roller for cutting and rolling flat tank heads of about any diameter. Lots of tanks in this part of the world because we heat with fuel oil, so 1 for every house/building. It might pay to call around for someone close to you.
For a barbeque, I use retired water pressure tanks. They show up at the dump here pretty often, usually because the bladder inside has failed. Don't know where to find them there, but you might start by calling people that work on well water systems. The right guy will be happy to have you haul one away.
I wouldn't have posted so many photos, but Cutter wants to see the dogs. Have fun.
Name:	homestead 08 072 (Medium).jpg
ID:	100076   Click image for larger version
ID:	100077   Click image for larger version
Name:	Mountain Shack 09 039 (Medium).jpg
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it."
“The thing about quotes on the internet is you cannot confirm their validity” Abraham Lincoln
Old 01-04-2013, 07:16 PM
pumpertruck's Avatar
pumpertruck pumpertruck is offline
Spinner of Wood
We get our tank heads from Texas. The ends are domed, not flat. I don't know if they are spun or stamped, but they have a 1/2 hole in the center. We use 10" up to 48".
I can find out the vendor next week.
Shorter of breath and one day closer to death.....
http://www.ibrbsantas.org/
Old 01-04-2013, 07:24 PM
Rolfsi Rolfsi is offline
Just job. Great idea!,,
Sent from my iPad using SFT
Last edited by cutter; 01-04-2013 at 08:15 PM. Reason: remove embedded image; upload attachment
Old 01-04-2013, 07:41 PM
Hey Fabber:
Are those pressure tanks galvanized?
RS
Old 01-05-2013, 11:25 PM
chumly2071's Avatar
Urban Gunfighter
Try Baker Tank Head. We used them when I worked at Vactor on our debris bodies. The large ones we used were 91" in diameter. They are in Ft Worth.
Old 01-06-2013, 01:39 AM
Originally Posted by Rolfsi View Post
Hey Fabber:
RS
Some older ones are. The newer ones I've seen aren't.
Depending on the pipe size, the ends of an expired propane tank may fit the purpose as well. Make sure to get all the gas out first - fill with water...?
Old 01-06-2013, 02:00 AM
Hey Rolfsi, Cam is right. Modern tanks generally have a rubber bladder inside that holds the water and air pressure fills the rest of the tank. That way there's no need for coating the inside. Outsides are probably powder coated or epoxy painted to guard against corrosion.
Old 01-06-2013, 11:16 AM
Thanks fellas. I have been wanting to build one for a long time. You guys just gave me some great ideas. I am glad we all have this forum to share thoughts and ideas from people with more experience than me.
RS
Old 01-11-2013, 10:18 AM
mking7 mking7 is offline
Thanks. I talked to them and they do sell to the public. But wow those things are high. $143 each for 24"x1/4". I'm thinking plan b is in order. :-)
