Old 08-02-2022, 12:15 AM
staybusy staybusy is offline
Default Scooter Axle
Just trying to put together a simple scooter axle and need some feedback so I don't ruin things as usual
Have a new tire with hub, the shaft fits perfectly inside flush. I"m planning on welding a large washer onto the hub / wheel, and connecting the sprocket to the washer with small bolts. (Image attached). The sprocket will drive the wheel but not the shaft.
For the outside attachment points I planned to use loops for the axles to ride in, with a steel bushing. Through that I'd put a bolt to lock the bushing to the shaft.
The motor will drive the sprocket -> tire spins freely on the axle.
Is that a good arrangement?
I'm too drunk to explain well, hopefully it makes sense.
ID:	165374   Click image for larger version
ID:	165375   Click image for larger version
ID:	165376   Click image for larger version
ID:	165377   Click image for larger version
Old 08-02-2022, 03:36 AM
If you are only going to have one driven wheel per axle then your basic arrangement sounds OK. If you want two driven wheels you're better off to mount them solidly to the axle and have the axle rotate.
Just be aware that when making rotating components that must run concentrically it's almost impossible to weld pieces together and achieve this. I would try very hard to get some pieces machined up to ensure that everything rotates smoothly. Depends a lot on how fast everything is going to be turning...
Old 08-02-2022, 03:38 AM
I cant tell if you can remove the bearings before welding
General rule when it comes to bearings and bushings, heat can damage them along with melting the grease or oil out of the bearing.
I don't think that wheel was meant to be motorized at any high speed..... pretty much a manual push cart wheel with low precision bearings.
other than the bearings I would consider doubling up the washer, have no idea what torque or speed a washer will handle.
Old 08-02-2022, 08:07 AM
Bearings are easily removable on this wheel. This looks like those little chinese scooters and tires are the big problem with them.
What you have looks like the Princess tires for wagons and hand carts. You can get the airless tires from them same size tire and bearings, but you never have to add air.
I would assume you have some tubes for spacers or collars to keep the tire and sprocket from wandering side to side.
Thomas Sowell
Old 08-02-2022, 01:26 PM
I'm using a 400w electric lawnmower DC motor (brushed). It will have a variable speed throttle. I'd imagine it will deliver a slow but decent cruising speed. The original motor on it was 150w.
Getting everything aligned might be an issue for sure. The washer fits almost perfectly on the hub so I should be able to align it nicely. Welding is probably the way I'll screw it up
Yea if the welding heat penetrates into the bearing it's definitely not good. I didn't think the bearings could be removed so I figured I'd try to slowly tack weld it (tack, let it cool, tack, all the way around the washer).
How I can get the bearings out?
One issue is that I'm welding that washer and sprocket to where one of the bearings is, so if I remove it for welding I won't be able to get it back in.
The scooter is a crappy E150 (image attached), the back wheel was basically a roller blade wheel and the motor was only 150w. Trying to fix it up a bit for my nephew.
Forgot to mention I have some shaft collars and pipe (spacers) I can use, not sure which I'll go with yet.
Old 08-02-2022, 01:38 PM
More pics attached
ID:	165380   Click image for larger version
ID:	165381   Click image for larger version
ID:	165382   Click image for larger version
Old 08-02-2022, 06:21 PM
I think I remember 3/4" axle is the size. take a 1/2" rod and place it through the bearing and then angle it so it catches the other bearing from the backside and tap it out. These bearings have a pressed steel outer race and are not real hard to tap out.
Thomas Sowell
Old 08-02-2022, 06:57 PM
You'll need a sleeve larger than the bearing to weld to the outside of the bearing pocket so you can get it back in.
I would try to flange the outside of the sleeve to bolt the sprocket on so the bearings still can be serviced.
