Old 06-25-2022, 08:01 PM
OldRedFord's Avatar
Kibble King
Default Hydrulic system questions
What is this arrangement on my sawmills hydrulic system?
1st picture...
Pressure gauge? There is a handle to the right on the end that says "pressure increase"
There is also what I think is a shutoff valve under the pressure gauge?
#2 I assume this is a relief valve or regulator of some sort?
I thought the supply and return sides wpuld be separate but they both run through those fittings.
ID:	165081   Click image for larger version
Tim
Old 06-25-2022, 09:15 PM
Flow control and pressure relief. Never seen ones that old.
Do you have a hydraulic drive for the carriage?
Thomas Sowell
Old 06-25-2022, 11:09 PM
Don't know much about Hydrulic systems. I thought I had dealt with some old shit. I think the "Stone Tablet" manuals are available from Moses.com/manual
Old 06-26-2022, 07:03 AM
randydupree's Avatar
Why, Hell Yes!
you guys read my mind,but i was thinking Noah may have owned that mill one time,before the flood.
Old 06-26-2022, 03:44 PM
OldRedFord's Avatar
Kibble King
Yes. That's exactly what this setup is. Runs a spool valve and that runs a gear motor that runs the cable drum for the carriage.
Tim
Old 06-27-2022, 08:50 AM
What an abomination you’ve got into.
I still say walk away from that thing, it’ll be your best option in the long run.
Old 06-27-2022, 03:22 PM
OldRedFord's Avatar
Kibble King
Why do you say that?
The hydrulic carriage drive is a Tyrone Berry model SMA 213. Purpose built for what it does.
Tim
Old 06-27-2022, 03:48 PM
It could very well be purpose built.
Between a swing saw you’ve already said you have no plan to use, a circular mill that eats wood and makes sawdust, and uses a HUGE chunk of real estate, a driptroit that excels at making noise and oil spills and not much else, and all of it being a huge project just to think about making it ‘useful’, I can’t see why I would suggest to walk away from it.
There are several here that have seen what both circular and band mills can do, (myself included), and I haven’t seen too many comment that this was a good idea, or that they are excited to see it in action.
Hey, whatever floats your boat I guess, but I’m a vote for a small portable band mill. Heck, if I was still in Onterrible, not only would I look at the option, but I’d maybe look at electric. If it would run off a portable welder/generator, than it’s one less ICE to maintain, and simply look after the welder instead.
