![]() I figured if they were not magnetic, they are probably mostly SS and I don't have to worry about rust, but if they are magnetic, it's probably a mixture of metals. The problem is, the head of the valve is non magnetic, but the back end of the shaft is very magnetic. This pen shows the point where the magnetism stops. Above the pen is magnetic, below the pen is not. I guess I could just polish them up and clearcoat them, but if they won't rust, I'd rather just do that. Any input? |
Be careful some are filled with liquid, and may explode when heated.
Which end are you welding?
Chris One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors. Plato LET'S GO BRANDON!!!! |
I'll be cutting them down to about 2" long including the head, so I'll be welding them right at about where the pen is.
That's what I was thinking Sodium filled exhaust valves.
If you cut them with a hacksaw you should be OK. AFAIK, the sodium is in the stem
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. “The word ‘racism’ is like ketchup. It can be put on practically anything — and demanding evidence makes you a ‘racist’.” Thomas Sowell |
Cutting sodium filled valves:
https://www.youtube.com/watch?v=JfdWCHlNeSs Valve steels 101: https://www.enginebuildermag.com/200...r-hot-engines/
USMCPOP Last edited by USMCPOP; 06-25-2022 at 09:06 AM. |
I’ve already cut these and welded them. These are solid. Good to know that some are sodium filled though…
