Old 06-18-2022, 02:28 AM
CaddmannQ's Avatar
Default From the House of Baaaad Brakes
I broke out the TIG welder again today, and it went well. I was frustrated with the welder and I couldn’t seem to get it to pulse as needed.
I finally shut off the pulse and used the pedal and suddenly I was happy again.
Anyhow, I am customizing a bike for some rat rod club and made these funky brake arms up from two sets and some chain.
Old 06-18-2022, 09:31 AM
Ironman Ironman is online now
Do these rat rod guys have loud pipes?
Thomas Sowell
Old 06-18-2022, 10:00 AM
astronut's Avatar
astronut astronut is offline
That's a neat looking setup!
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 06-18-2022, 10:34 AM
CaddmannQ's Avatar
A few are motorized, but it’s a bicycle club.
Old 06-18-2022, 12:12 PM
Motorized, eh?
Some people should stick to their wheelchairs and sucky cups
Thomas Sowell
Old 06-18-2022, 10:45 PM
It took me a bit to realize how you did it cause bikes are unfamiliar to me. I see the weld is well hidden or you did fusion without a filler rod. I have done that on some delicate stuff and I was surprised how well it worked.
With Tig, I'm at that 'uncertain' level of experience, where you have good days and some days not so.
Thomas Sowell
Old 06-19-2022, 01:31 AM
CaddmannQ's Avatar
I Changed the tungsten six times for four welds, buddy. It seems to be drawn magnetically to the puddle.
First I bobbed off a left and right brake arm. I stacked identical unbobbed arms on top them. I took an unplated flat washer and ground it to fit inside the joint.
Then I could just blast right through the crack into that thick flat washer and not have to worry about burning back at the edges. This made for a very strong assembly.
I marked the hidden washer with an arrow because it’s not too obvious what’s going on in this photo. There was no welding in this area. That’s a really awful photo because the welded assembly sitting in a can of washers and springs.
I used some regular filler rod & I ground the welds down and burnished them so the parts would look nice. That’s why the structural washer was important.
ID:	165028   Click image for larger version
Old 06-19-2022, 01:40 AM
CaddmannQ's Avatar
I did take a photograph that shows two welds after they were dressed off.
Old 06-19-2022, 11:08 AM
Do I have a life?
Maybe loud cards in the spokes?
Lookin' good, Cadd--I like the incorporation of the bicycle chain.
HF 80 lunchbox w/tig
Old 06-19-2022, 07:34 PM
CaddmannQ's Avatar
They’re mostly into these rusty paint jobs that look like you just pulled something out of a junk pile.
