Old 05-22-2022, 08:53 AM
Folkpunk Folkpunk is offline
Default What machine does this
Could anyone tell me what machine I need to make these beveled holes?
Name:	Screen Shot 2022-05-22 at 7.49.20 AM.jpg
Old 05-22-2022, 10:23 AM
It's a punch / die set. I've made one size for a friend a few years ago .
...lew...
Old 05-22-2022, 11:09 AM
...lew...
Thanks. So would the HF press work? What die set are you referring to?
Old 05-22-2022, 12:43 PM
jniolon jniolon is offline
dimple dies
https://www.eastwood.com/eastwood-di...=google&wv=3.1
Old 05-22-2022, 12:53 PM
chumly2071's Avatar
Urban Gunfighter
Swagoffroad.com has them in tube and pipe sizes (pipe for using conduit knockout punches).
Sent from my SM-G986U using ShopFloorTalk mobile app
Old 05-22-2022, 01:34 PM
Originally Posted by jniolon View Post
Sweet. Thank you!
Old 05-22-2022, 01:35 PM
Thank you!
Old 05-22-2022, 06:43 PM
camdigger's Avatar
Roving Reporter
https://youtu.be/S0ECpN8Wvug
Before you get out your wallet watch the vid from Make it Kustom in the link.
Bumper material is typically on the heavy side for dimple dies, but it obviously can be done. You may want to consider fine thread bolts for your dimple tool to reduce torque needed.
Alternately, dimple dies are an easy lathe job.
Old 05-22-2022, 08:48 PM
Videos like this are what made me get into this stuff in the first place. Thanks for the link!
Old 05-23-2022, 09:28 AM
An enerpac (or similar) hollow cylinder makes short work of these.
HF similar kit that you make your dies fit:
https://www.harborfreight.com/hydrau...kit-96718.html
