Old 03-26-2022, 09:55 AM
Do you have a tuner on your truck? Not sure if this actual transmission requires it, but reading thru the selling points on website, mentions it several times.
I have a Bully Dog tuner.
LET'S GO BRANDON!!!!
Old 03-26-2022, 09:58 AM
I would drop the pan and do them both. And change the filter and oil at the same time.
And yes, this should be done every 60K if you are pulling a load.
These trannys will give good service if maintained but especially in diesels, they are treated as if they were a standard box, and there is waay to much torque pushed through them. You never hear of a 48RE failing on a gas engine and they are ignored on them too.
Chris is gentle with it and never burns rubber
Mine only shuddered in OD.
Old 03-26-2022, 10:01 AM
The one I linked has a 3 disk torque converter. Sent them a message and asked about Warranty coverage traveling in Canada. Gery knows why.
Old 03-26-2022, 02:04 PM
probably not good to tow in OD on hilly country, or switch out as needed.
Thomas Sowell
Old 03-26-2022, 04:28 PM
Originally Posted by midmosandblasting View Post
I know I am going to hear snake oil from shade . I had shift issues and shutter on a 2001 ram 4wd with a gas engine . One bottle of Lucas transmission and shift back to normal and no shudder .I think mine was sticky shift valve .
SMH... its not my transmission and you have been warned...
Old 03-26-2022, 05:17 PM
I have posted the procedure for adjusting the bands if anyone wants it.
Old 03-26-2022, 06:33 PM
Windy_Acres's Avatar
Chairman of the Headboard
That transmission is so simple and based on ancient T/F design, Im a bit shocked how much mola they are getting for one, but I guess everything costs more now...
Good luck Chris, in whatever direction you end up going !
Old 03-26-2022, 10:15 PM
Where'd you put it Ron?
Thomas Sowell
Old 03-26-2022, 11:19 PM
It on a thread here somewhere... I can scan it and post it again tomorrow.
Old 03-27-2022, 08:00 AM
The O/D is a separate unit off the end of the transmission. It uses hydraulic pressure to hold the clutch pack together when in use. A plugged filter or some crap in the pressure regulator valve will give those symptoms, because of low pressure. The pressure reg is just a dump valve controlled electrically to dump into the sump when pressure gets too high.
Yours may not close properly and dump a little all the time. This is very accessible with the pan off.
Thomas Sowell
