Old 12-05-2020, 10:48 AM
eglide88's Avatar
eglide88 eglide88 is offline
Default European railroad rail
Can it be made into Damascus steel for tooling, chisels and other cutting tools?
I have a chance to get about 10 feet of it and was wondering is it worth it.
Old 12-05-2020, 02:03 PM
kbs2244 kbs2244 is offline
If it is like US rail, it has different "layers" of steel.
The very top is hard to be wear resistant
While the lower part is softer for bendability
Old 12-05-2020, 05:35 PM
Damascus steel? Are you cutting strips and forge welding in other strips to make patterned steel?
I don't know about European rail steel, but American steel in the modern age is medium high carbon. Here's what what one re-manufacturer says of used rail steel:
https://jssteel.com/our-rail-steel-p...-steel-angles/
Strong but tough stuff, about like 1065. No way they could afford to layer steel given the vast amounts used.
It's not "tool steel", but you could use it to make an axe or a chisel.
Old 12-05-2020, 05:56 PM
Here's some various rail steel from various countries:
https://www.jfe-steel.co.jp/en/produ...og/d1e-001.pdf
Old 12-20-2020, 09:54 AM
I wonder about this "strip on the top" in view of this cross section of a piece from a curve. Taken from the curve just above Harrisburg Pa where the line goes from following the river to the bridge across it .
...lew...
Name:	RR section on curve .jpg
Old 12-20-2020, 12:59 PM
Some rails are head-hardened to a depth. Worn rails can get to looking funny.
ID:	158888   Click image for larger version
Old 12-24-2020, 03:59 PM
Raspvtin Raspvtin is offline
If its for damascus cut a sliver heat treat it and see how well it hardens. The main issue with rail to look out for is cracks and stress fractures when forging as they can be usable for rail with micro fractures but not so much for forging.
I'm assuming these are relatively modern post 1900 rails as with european rails it is possible for them to be old enough to be wrought iron where as its much more rare to find US rails that old.
