  #31
Old Yesterday, 07:36 PM
Ironman Ironman is online now
First one shows the grease zerk I drilled and threaded into the back of the stick. I reduced the outer diameter of the bushing in the grease nipple site so that if the bushing migrates around the grease can still flow around the groove and into the bushing lube hole I have drilled now.
The last two show the thumb in the active and parked positions. Now comes the brace and bracket. Got a start on it, and then it was 6 pm.
ID:	152562   Click image for larger version
ID:	152563   Click image for larger version
