Old 09-15-2022, 04:51 PM
Default Got shorted on led lifespan
I put a Sylvania 8 watt Led bulb in light above kitchen sink last year on 10-2-21. (Yes, I am anal enough to write the dates on the bulbs )
This light stays on 24/7. Only time it has turned off was in power outages. It was only 1/4 bright tonight.
Box says it’s life span is 9 years, at 3 hours a day. That’s 9609 hours. This one only lasted 8400 hours.
Usually I get better life span outbid things when they do not get turned and off a lot. Have had regular bulbs go a couple of years.
But, I guess it should have only cost me $11.34 in electric costs for 50 weeks, vs $75.60 for a regular incandescent bulb. Maybe it was worth the extra $3 Cost per bulb.
Old 09-15-2022, 05:37 PM
4-13-1949 to 5-21-2023
I'd say you did well enough on the cost savings.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 09-15-2022, 08:46 PM
Do I have a life?
Out of principle, you should demand a replacement!
HF 80 lunchbox w/tig
Old 09-15-2022, 11:50 PM
(Yes, I am anal enough to write the dates on the bulbs)
If you're anal so am I. I've written dates on bulbs for years...
Old 09-16-2022, 05:35 AM
Led's are likely good. the issue is the power supply's in side, now a days electrolytic capacitors if lucky last 5 years, on a bad run 2 years.
they may have figured in a 3hr duty cycle for cooling.
EL caps do not like heat they dry-up and fail, you may have to change brands of lights.
Old 09-16-2022, 08:09 AM
Ah BUT that probably voids the warrantee . :-) All that ink on the bulb interferes with "proper" cooling. :-) Or some such "legalese" :-)
...lew...
Old 09-16-2022, 05:00 PM
Do I have a life?
I just had a 4' LED (fluorescent replacement) start flickering on me. Luckily had replacement in stock. Maybe 2-3yrs old? I may just have to dig out the receipt--I think I paid $4 for it...
Old 09-17-2022, 05:43 PM
yooper yooper is offline
Default bulbs
I've bought 10 Feit 4 ft Fluorescent replacement led bulbs from Menards two years ago , four have failed , I keep two for spares and return the bad ones , they have a 5 year warranty , so far they have replaced them - no questions asked
LED's don't seem to last longer than fluorescent , The fluorescent tubes I had usually lasted 5 years or more .
Old 09-17-2022, 07:33 PM
TEK's Avatar
TEK TEK is offline
And air filters, and oil filters, ad infinitum
-----DozerDan
