Old 08-30-2022, 09:28 PM
Do I have a life?
That,,,, is a monster for sure.
Yup, don't let it suck you in!
HF 80 lunchbox w/tig
Old 08-31-2022, 01:00 AM
That 10” thru bore would be sweet for some things, and a big pita for others.
If you have an extra three jaw, chuck it in the four jaw, dial it in and away you go for a lot more ease of use.
I’ve had three chucks setup at once before when I needed to do small work and the only lathe available was a biggun.
Old 08-31-2022, 05:06 AM
A problem with big lathes and small diameter parts getting the surface speed you need for a nice finish.
Old 09-08-2022, 01:09 PM
Making a 4 ton roller. Rough machining by oxy torch.
One of the things my dad taught me is that the world is your bathroom -- Quick Dick McDick
Old 09-13-2022, 08:34 PM
Don_S Don_S is offline
A #6 tip should cut 3 inch like nothing. Did you notice the oxygen bottles all ganged together in the beginning where he is cutting the ship crank? That's the real issue with a big tip.
They are designed for laminar flow at probably no more than 60 psi but will freeze up the bottle due to high volume flow.
I have a 2.5" heating rosebud and when heating and bending 3.5 x 7" material, I had to heat the bottle with a 1500 watt heater to keep the valve and regulator from freezing.
We've used Dewars of liquid O2 instead of tanks on big rosebuds at the last place I worked.
Old 09-15-2022, 08:43 PM
On the subject of big lathes and poor safety practices, how about walking on a pile of round bar in flip flops while operating a lathe big enough to kill everyone in the shop at the same time?
https://youtu.be/s4mb_Pbxdls
Old 09-16-2022, 05:19 AM
Hey, at least the one guy had a covid mask on! lol
Old 09-22-2022, 04:06 PM
This video shows the new industrial footware and welding shields and well as the correct way to protect the ways of a lathe when loading stock
wow, that's crazy these guys don't use any common sense!
