  #111
Old 09-13-2022, 05:02 PM
Nope, those are outside jaws, chances of finding the proper matched set for ‘inners’ are slim. Even if you do find them, unless they are ground/fit to that specific chuck, they won’t run 100% true.
Too bad shipping is stoopid pricey, I likely have a chuck with both sets of jaws. If I don’t at home I know there would be one in the storage trailer in Onterrible.
  #112
Old 09-16-2022, 11:41 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
You're very kind, but don't worry, the Chinaman will provide.
I must upload a video later but my farmer's toolpost grinder did the business just fine.
I spent 20 minutes cutting it, ran the lathe in bottom gear. Stopped every few minutes and put a wet rag on/into the bearing to keep it cool. Spent a lot more time cooling than cutting. Surface finish was perfect and only gave it a run of a stone for a second to clean up the faintest of burrs. The way it was going in meant it only needed a taper on one edge so I just fitted it like it was.
About 3 hours from the UPS man to having it machined, the box rebuilt and refitted.
I've a mini digger coming in the morning so badly need the tractor running for dumper duties
ID:	165738   Click image for larger version
ID:	165739   Click image for larger version
ID:	165740   Click image for larger version
ID:	165741   Click image for larger version
  #113
Old 09-16-2022, 08:15 PM
Glad to hear it worked out.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
  #114
Old 09-17-2022, 12:57 PM
A lathe is a wonderful tool
