Old 06-23-2013, 11:22 PM
rickairmedic's Avatar
SFT HVAC Guru
Default My old 62 Ford
Well I have 5 weeks left to get this thing moving so I will post it here and on my Truck forum to keep me motivated to get it done
I am putting a 1962 Ford F100 unibody truck ontop of a 1988 Ford Crown Victoria chassis with the full crown vic driveline .
The first set of pictures are the car and truck in question .
Rick
ID:	106974   Click image for larger version
ID:	106975   Click image for larger version
Old 06-23-2013, 11:25 PM
SFT HVAC Guru
Ok this is last weekend after finding enough room in the garage to work on it .
Rick
ID:	106977   Click image for larger version
ID:	106978   Click image for larger version
Old 06-23-2013, 11:33 PM
SFT HVAC Guru
This is this weekends progress . The old chassis is out and the motor and tranny are loose ready to be pulled off and put on craigslist . The old chassis is going to a buddy of mine who is going to build it over the winter for a 64 F100 he is building .
Rick
ID:	106980   Click image for larger version
ID:	106981   Click image for larger version
ID:	106982   Click image for larger version
ID:	106983   Click image for larger version
Old 06-23-2013, 11:38 PM
SFT HVAC Guru
More of this weekends progress .
The next tasks are yank the motor and tranny and stuff them in the shed deliver the old Chassis to my buddy . Then the Crown Vic can move into the driveway so I can pull the doors , trunk lid and front clip off of it then the interior comes out and then the Sawzall comes out until I am left with the chassis firewall and floorpan of the crown victoria . I hope to have this done by next weekend .
Rick
ID:	106985   Click image for larger version
ID:	106986   Click image for larger version
ID:	106987   Click image for larger version
Old 06-23-2013, 11:52 PM
mudbug's Avatar
mudbug mudbug is offline
Cranky Crustacean
The picture progression makes that look fast and simple---IT AIN'T. That's a tremendous amount of labor & knuckle busting work.
Good Luck ! At least you opted for a new undercarriage which simplifies things a lot. You just have to make the stuff above the frame fit..
Old 06-24-2013, 12:06 AM
SFT HVAC Guru
LOL yep my buddy who has been popping over to lend a hand when needed asked me how I was going to get the new chassis under the old truck I told him I am leaving enough hooked up on it that I could drive it under if I wanted .
The skeeriest part of the progress so far was lifting the body 3-4 feet in the air to get the old chassis out .
Rick
Old 06-24-2013, 12:30 AM
mudbug's Avatar
Cranky Crustacean
That's what they make A-frames for... LOL
I've got a '47 Ford chassis ,but unfortunately I got there too late to snag the I-beam front axle the idiot hauled it for scrap... probably got $10 for it but then he just gave me the chassis which weighs a bunch more & a huge homebuilt press with a 5" vise mounted to the side for $20 (I shouldn't complain except a 47 Ford axle ain't easy to find anymore)
I'm constantly amazed at what constitutes "junk" in the human mind..
Old 06-24-2013, 12:37 AM
SFT HVAC Guru
An A frame woulda been handy I used the old cherry picker . We started at the back and got it up on a stack of 3 cinder blocks and a 4X4 I am 5'9" and could see the whole bottom of the truck by the time we got the back end high enough . Then we moved to the front and lifted it up onto a stack 4 high of cinderblocks plus the needed 4X4 then went back to the back and lifted it up enough to get the last cinderblocks under it before rolling out the chassis .
The cinder blocks are stacked 2 wide and crosshatched so they are quite sturdy once the chassis was out I dropped the whole thing back down to 2 blocks high for safekeeping while I go to town on the crownvic .
Rick
Old 06-24-2013, 04:24 AM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
wow. that is a lot of work in two days.
Klaatu barada nikto
Old 06-24-2013, 09:01 AM
SFT HVAC Guru
Mike believe it or not that was all done by Saturday night and I took SWMBO to dinner and a 7:30 movie Saturday night . She even let me see the new Fast and Furious although we had seen 2 of her movies in the last month .Sunday I put a Starter in her truck got the motor and tranny on the chassis ready to pull and then took her shopping . with any luck my neighbors F250 comes home from the shop today and I can deliver the chassis tonight and get the Crown Vic moved in place to begin the carnage on it .
Rick
