Old 08-31-2022, 02:10 PM
NOBLNG NOBLNG is offline
Default Weak Fifth Wheel slide motor
The slide motor on my 2010 Keystone Cougar has a hard time getting the slide all the way out. The dealer wants a ridiculous $1200.00 for the part and 2hrs labour to install it. I can get a motor and gearbox for around $600.00 I think, and I watched a video where it looked like 1/2 hr job. Or, I could remove the motor and have it rebuilt locally. I am leary of buying a motor online that may be of dubious quality. I have found no motor only replacement without the gearbox. This should be a very common motor, so the price floored me! Any tips or thoughts?
ID:	165587   Click image for larger version
ID:	165588   Click image for larger version
ID:	165589   Click image for larger version
Old 08-31-2022, 03:44 PM
Make sure everything else is well lubed and moving freely, and not adding to the load.
You could try these guys too,
https://youngfartsrvparts.ca
Old 08-31-2022, 07:27 PM
Thanks, Everything else seems to be in order and I don’t see the motor I need listed in your link.
Old 08-31-2022, 07:33 PM
I have found one on amazon that claims to be made in USA (better than a china pos) for a reasonable price, but it is 5800 rpm instead of 9500 rpm. That is not a deal breaker, especially if the lower rpm motor would put out more torque. All else being equal…do rpm and torque vary inversely in an electric motor? They both have the same 18:1 ratio in the gearbox, so the slide would just move slower.
https://www.amazon.ca/RV-Slide-Out-M...07MR8JLZ8?th=1
Old 09-01-2022, 07:41 AM
Generally lower rpm has more torgue. If they list current draw that would be my guide. Power consumed equals HP
Old 09-01-2022, 08:07 AM
They both say 30amp. Somewhere along the way I read that they only have a 20% duty cycle which seems pretty low.
Old 09-01-2022, 11:05 AM
I noticed the low duty cycle too. 1 minute on, 4 minutes off. But it’s not like you are moving in in and out constantly. But is one minute enough to extend it without having to stop and let it cool down in one shot?
Old 09-01-2022, 02:10 PM
I recently sold my camper trailer. It had a hydraulic pump and ram. The little skateboard wheels that ran in a track had seized and worn flat. It still went in and out, can't beat hydraulics.
Old 09-01-2022, 06:42 PM
I’ve never timed it but I’m thinking around 30 seconds or less to run it out.
The wheels are OK on mine. I can get the USA made 5800rpm motor and gearbox for $350 from a canadian supplier, so that’s what I’ll do.
