Old 11-06-2006, 08:54 PM
Default What do ya think
I don't know about the rest of you but I hate extension cords. This is a idea for a 220 volt hand reel. Before I go to all the trouble to make one I would like some opinions please. I would make it big enough to take about 50' of cord. You would have to have a pig tail to use from the outlet to the reel and take it off before unwinding or winding the cord.
Old 11-06-2006, 09:01 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
Looks like a good idea.
Build it and show us how it turns out
Jeff
Old 11-06-2006, 09:12 PM
Tom Zachman's Avatar
Dodge City Marshal
What are you leaning towards; small spool with lots of wraps or medium spool with about 10 wraps?
New sig line:
Old 11-06-2006, 09:14 PM
Pile Buck's Avatar
North West Redneck
I agree, looks like you’re onto something there.
Here is a picture of the best reel I’ve ever been around, it’s shop built. Will take a very long cord also.
Disclaimer:
I’m neither a professional or certified weldor! :evil:
Old 11-06-2006, 09:15 PM
Bolt Bolt is offline
That should work just fine. I run a similar setup on my service truck for my welding leads, argon hose, oxy acetylene hose, air hose, and a 12/3 SJ cord, for either 120 or 240.
So you have the shaft going through the bearings and out past the braket, with your plug on the end of that? You could also just mount a plug on the side of the reel and plug in there. Could do it on the other (handle) side. The only problem I see here, if you are running high amperage loads it is best to roll off all the cord and then use it.
I always like your drawings, tell me again what program you use?
Old 11-06-2006, 09:16 PM
I would think the spool would have to be about 12" plus in dia. with about a 4" dia hub.
Old 11-06-2006, 09:19 PM
wow now that is a reel!!
Old 11-06-2006, 09:20 PM
Dodge City Marshal
A 4" hub is pretty tight for large conductor cable... Also Bolt is right about that coil adding inductance to the alternating current flow.
New sig line:
Old 11-06-2006, 09:25 PM
OK bigger is always better what size do you think? I do agree that the cord should be all the way out if used for a long time with steady welding.
Old 11-06-2006, 09:28 PM
I thought about mounting the plug on the handle side but was afraid it would be knuckle buster. The drawing program is called "Smartdraw" and how about some pics of your reels?
