Old 11-05-2006, 03:03 PM
tenfingers tenfingers is offline
Default Flatten Plate?
I have a 36 x 60 half inch plate to use for a worktable top. The problem is it has a bow of about 3/4 in lengthwise.
I thought that I could bolt it to the table frame and pull it down flat. The table frame is 3" channel. No luck there.
I've been told to heat one side with o/a. I can see how that works with I beams but I don't see how it would work with plate. (how would you heat one side of a plate?)
I thought about putting the ends on blocks and driving over it with my Ford Ranger but I don't want to put a bend in the center and still have the warp to deal with. Also the pickup may not be heavy enough.
Old 11-05-2006, 03:20 PM
AntiBling's Avatar
AntiBling AntiBling is offline
Send a message via AIM to AntiBling Send a message via MSN to AntiBling
If it were me I would put it down on some flat concrete and drive over it.
Century Super Star
Miller 175
Thermal Dynamics Cutmaster 51
The true weld test isn't done by bending metal or with x-rays, the true testament to how strong a weld is how much you cuss trying to take a piece off that you welded in the wrong place. ~ AntiBling
tigman250's Avatar
The Right Stuff
to save me from a long drawn out answer, here is a link to the Miller website where this was discussed not too long ago. he tried what you are describing with the truck for weight and didn't have much luck, as you will read with some well placed heat you will be able to bring it back nicely.
Old 11-05-2006, 03:25 PM
Photomask's Avatar
Photomask Photomask is offline
Big Stone
Heat with O/A running heat stripes, from the convex side running 90 degrees to the axis of the bow.
This can also be done by running several arc welding beads in the same manner as O/A, then grind them flat.
Do a little of either at first, allow it to cool, grind as needed.
Then monitor progress and repeat until flat enough.
Old 11-05-2006, 04:29 PM
Pile Buck's Avatar
North West Redneck
Here you go, I’ve seen this done before!
Name:	Heat plate.jpg
ID:	17199   Click image for larger version
Disclaimer:
I’m neither a professional or certified weldor! :evil:
Old 11-05-2006, 06:22 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
I have straightened things with an arc welder before.. weld a bead on the curved side in the middle.. when it cools it bends back... same concept as the OA but more accurate.
but then you ahve to grind off the weld.
Old 11-05-2006, 06:49 PM
I guess I would use a welder on the plate. Like Bucks drawing. Just remember the problem has to get worse before it gets better. It takes time!! Let it cool before adding more weld.
Old 11-05-2006, 06:53 PM
Pile Buck's Avatar
North West Redneck
Or use water / compressed air!
Disclaimer:
Old 11-05-2006, 07:25 PM
tigman250's Avatar
The Right Stuff
yeah, when you start heating it will go the wrong way, don't worry it will come back! i love the looks you get when you start straightening something with heat and the customer is standing there wondering what the heck you are doing!!! :evil:
