Old 08-03-2006, 10:13 AM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
And it would likely be a rare day to apply a 50A load for more than a couple seconds.
Old 08-05-2006, 05:26 PM
houlibar's Avatar
houlibar houlibar is offline
Lord of the Reins
Default The Mother of all Power Strips
Okay, I read Ron's thread Center Tap Transformer. So if I understand correctly, you can use the 240V full KV receptical of an engine drive to power more 120V recepticles if the two on the generator aren't enough. You could use each of the two hots and the neutral to power two separate 120V buss's of up to 40 amps each.
Has anyone ever made up a box like that? I'd like to see how it's done.
Old 08-05-2006, 07:52 PM
Tom Zachman's Avatar
Dodge City Marshal
Physically; YES. The limits of the circuits are breaker'd but the real loads can't exeed the total (engineered) output of the genset.
Your two new 40A X 120V loads ='s 4800 Watts. How close is that to the rated output of the genset? Can you then add the power (in Watts) available from the two existing 120V recepticles (prolly 2400 Watts) and not exceed the rated output?
We typically use electricity to run resistance and/or inductance devices. Heater/light coils are resistive and motors are inductive. Resistance loads remain (mostly) constant during use. Inductance loads can vary wildly during use.
New sig line:
Old 08-07-2006, 05:26 PM
houlibar's Avatar
Lord of the Reins
Tom, the generator is rated at 9500W, continuous. The other 120V recepticles are breaker'd for 20A each. So I guess that would only leave 40A or another two 20A recepticles from each hot wire on the 240V plug. I was thinking more of a redneck power strip with say six or eight 15A recepticles. Something to get by in a power outage in the home. Plug in the fridge, some lights and maybe run the washer/dryer.
Old 08-07-2006, 05:40 PM
9500W = 79.2A at 120V = 39.6A at 240V.
Old 08-08-2006, 08:57 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
Doesn't that 14-50r allow for up to 39amps @ 120v?
It's 39 amps either 240v or 120v correct? Can't he just wire up a 14-50 Plug and at the other end split it to 2 5-15 Rs? Then run 2 Power strips with CB's on them?
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
Old 08-08-2006, 09:13 PM
Broccoli1's Avatar
I see where Tom got his response because you said 40 amps EACH (earlier) not 40 amps available, which you corrected in this post
You can make yer Redneck Power strip Over thinking it myself. I'll see if I can get a Pic of the Splitters we use on the Honda 7000s- which have the 30A 125/250V Locking Plug
NEMA Plug Number:
L14-30P
Same idea but just a lower rated Plug.
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
Old 08-10-2006, 06:09 PM
Broccoli1's Avatar
Here ya go Scott.
Pic Plug 3 has a it wired to a Bates connection and then out to 15ampers because we use various set ups but you would just wire directly to the 15s.
ID:	14798   Click image for larger version
ID:	14799   Click image for larger version
ID:	14800   Click image for larger version
Ed Conley
MM211 AS
MM252
Spoolmate 100
SO 2020 Bender
Miller 125c Plasma
TA 185
