Old 02-13-2022, 04:05 PM
Windy_Acres's Avatar
Chairman of the Headboard
Default Buying a new Rotating Vise, Yost ?
If there was money to set on fire, Id be buying an BIG USA Wilton, but need to make do with something from China, and for doing cylindrical holding work. Just had the option of dropping $5 Bills on a brand new massive Wilton Tradesman, but its a machinist style, I need something that is friendly to round items, and the ability to rotate is a must.
Mostly aware this kills the strength of the vise, but Im not going to be beating the shit out of things, I have the proper tools to do what I need and beating things to death is not on the menu. Ive looked at used and the shit being offered locally is just so abused, and over priced.
Yost seems to have a nice vise that might fit my needs, thought Id shop past you guys in the event Im missing something. Would not mind something larger, but I think this would work, for mostly general maintainance/driveline/tranmssion part holding work.
Yost 750DI $211 delivered ( its gone $10 this week ! )
Extreme-Duty Casting Clamp force: 13,400 lbs. and Torque rating: 316 Ft-Lb
Made from heavy duty 65, 000 PSI Ductile Iron castings, 3x stronger than cast iron vises
Jaw Width: 5" (12.7CM) x Jaw Opening: 5" (12.7CM) x Throat Depth: 4" (10.2CM) x Pipe Capacity: 0.125”D x 3.5"D (0.32CM x 8.9CM)
Vise head rotates 360° with respect to the vertical, locking at every 30° or (12) twelve different locking positions and equipped with a large 3.5" x 2.7" (8.9CM X 6.9CM) anvil work surface;
360-degree interlocking (geared) swivel base with (2) lock downs adjusts the direction of the jaws for proper placement.No-pinch main screw handle
Machined Q235 steel main screw 0. 75"D with rolled single acme threads at 4 threads per inch
Replaceable Hardened Steel Serrated (Top) Jaws and EXCLUSIVE SELF-ALIGNING Pipe Jaws
0.51"D x 9. 5" (1.3CM x 24.1CM) Long handle with rubber bumpers
Base mounting tabs: (4) x 9/16"D (14MM), mounting hardware not included.
Warranty: Castings – 3 years
https://www.amazon.com/Yost-Heavy-Du.../dp/B00CBL62HQ
Name:	yost 750-DI.jpg
Old 02-13-2022, 05:23 PM
Harbor Freight just started selling Wilton clones https://www.harborfreight.com/hand-t...es-anvils.html.
Old 02-13-2022, 05:30 PM
Thanks for the that...
There is a 5" Doyle that says " NEW " on the page, Ive never seen that one, its very similar to the Yost, for $40 less... in my travels I will have to swing through a store and have a look, would love to know what it weighs. The Yost is supposed to be 60 pounds.. like to find heavier, but that may not be in the cards...
Old 02-13-2022, 08:25 PM
I have a cheap China clone of that yost on my home bench. I think my dad bought them ( had two of them at least). For about $75 each 25+ years ago. One lived outside mounted on a semi rim, moved around as needed. I had old shop teacher talk me into selling it to him about 10 years ago.
The other one has withstood the shop abuse. The pipe jaws did come out and are misplace now. The handles have been straightened a couple of times, I’m just waiting to get some scrap chrome rod from work to make bed ones.
They are handy.
Old 02-13-2022, 08:55 PM
I can remember buying one at Sams club likely 30yrs ago, it kinda crumbled over the years,.. but owed me nothing ! Hoping for a little more quality this time around...
Old 02-13-2022, 10:08 PM
HD $189.99.
https://www.homedepot.com/p/Yost-5-i...0-DI/202786343
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 02-14-2022, 07:07 AM
Default Yost vise
I have a Yost model 208,swivel base got it 25years ago at a government auction for $250 along with a 6" ball bearing bench grinder..best auction score to date. The 208 used to be standard equipment on the older M35 Army 6x6 wrecker trucks-bolted to the front bumper!
From what I heard Eastwood bought Yost Vises in its entirety..hopefully they stay true to the quality vise Yost has been known for.
Any vise IMHO isnt money spent but invested..a vise is one of those shop essentials..just like a MIG welder
Old 02-14-2022, 10:01 AM
Thanks, yeah, 2 weeks ago, that was in stock @ The Homey Depot., now its out of stock, it appears if I go with the Yost, I have to buy from Amazon,. which I try to avoid,...
Old 02-14-2022, 10:03 AM
Thanks for the share, yes on the Yost site, in the contact area, you contact eastwood in PA, not Yost in MI, if you need something.
It looks like, if you screw up / break a Yost China Vise, you can buy parts for it. Not sure how it works with a Hazard Fraught Doyle Vise, speaking specifically post warranty period. From what I can see, just looking at the specs, the Yost has twice the clamping force, its about 10 pounds heavier, and Im all about value / function, so Im leaning towards the Yost, but plan to hit HF tomorrow to put an eyeball on the Doyle before I drop a hammer.
Old 02-14-2022, 01:50 PM
A fair amount more $$$ (and sorry about the Amazon link) - but Capri is made in Taiwan, 10 year warranty; this model is ductile iron, 60,000 psi material -
https://www.amazon.com/Capri-Tools-1...01&sr=1-4&th=1
Some of their other models are forged steel. I was looking at Yost, looks like mostly china these days. I'm looking at building a version of Wilton's "truck vise", will probably go with the forged steel Capri.
Obviously your money/your choice, but it's good to know what's out there... Steve
