  #111
Old 03-19-2006, 11:03 AM
Tom Zachman's Avatar
Dodge City Marshal
No reason not to use it. Inside humidity could become a problem but vents will fix that.
New sig line:
  #112
Old 03-19-2006, 11:30 AM
gagiii
Guest
Posts: n/a
thanks,
Humidity is probably the biggest problem in this country I am planning on some type of fans but I haven't run up on any to scrounge just yet.
  #113
Old 03-19-2006, 11:43 AM
Gagiii, do you mean galvanized corrugated iron?
  #114
Old 03-19-2006, 11:48 AM
gagiii
Guest
Posts: n/a
Yes, I guess that's what I mean. It's been called tin around here as long as I can remember
  #115
Old 03-19-2006, 01:07 PM
Well, I can think of several disadvantages, such as the acoustic properties but still, I think you are talking
about saving several hundred or maybe a couple of thousand dollars? I couldn't argue with that.
One of the real deficiencies to my little shop is the lack of inside sheeting; I have nothing but the purlins
and the white plastic cover of the insulation. I miss not being able to drive a nail into the wall to hang stuff on.
  #116
Old 03-19-2006, 02:09 PM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
Today 10:48 AM
Cutter, you still could. Just screw some plywood to your purlins inside. You would have to add one at the floor, but that is easily done. 5/8 or 3/4 ply on the inside should hold up most things you may want to hang. The purlins are just 16 gauge. Most decent self tapping screws can handle that easily. We used to hang sheetrock on them on several industrial buildings like that.
Just a thought.
Don
  #117
Old 03-19-2006, 08:51 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Exclamation Nice building
gagiii , I was reading one of your earlier posts about piping the air system in your shop ,here is a product I am going to use when I get my new shop built . No fighting with pipe wrenchs and no rust in the system . cut it with a tubing cutter and assemble it by hand and if you want to add or remove something (quick connector ,etc. ) you can take it apart easily . :evil: Dan www.garage-pak.com/
  #118
Old 03-19-2006, 09:09 PM
Dodge City Marshal
Nice link Dan.. Their Safety pages were good, too.
New sig line:
  #119
Old 03-19-2006, 09:28 PM
Lu47Dan's Avatar
Thumbs up Garage-Pak
Took two hours to find it the first time , was in the kitchen fixing coffee and heard the link on three guy garage but didn't write it down . Should have, memory not what it was tried every spelling for Pak but Pak But found it . Am in the process of designing the air system in my shop and will send it to them for a quote , when finished . Dan
  #120
Old 03-19-2006, 09:37 PM
Hobweld's Avatar
Hobweld Hobweld is offline
Hang on to your hat for the quote. I priced the small package at over 700.00.
Ouch
