  #91
Old 03-08-2006, 11:54 AM
Well gagiii, since no one else seems to be biting - as best I recall - the answer is something like this:
while pvc may be rated to handle the pressure you intend to run, it can degrade over time & become brittle & when it does blow, there tends to be a situation with sharp plastic shards flying all over the place.
When iron pipe gives, it generally just splits & whistles.
I don't have any personal experience with plastic air lines but I danged sure have encountered old pvc that would shatter like egg shells & that was enough to convince me. I guess I've reached the age where I prefer the drama in my life to be tamer.
I do know we've had a few brave guys report that they've been using pvc air lines for years with no problems but it generally is regarded as a needless danger.
  #92
Old 03-08-2006, 12:03 PM
X-ray's Avatar
X-ray X-ray is offline
Originally Posted by gagiii
I know that it has probably been answered here before but Why do you guys recomend using metal pipe for your air supply instead of PVC?
just wondering and thanks
Once at work we went the pvc route to pipe air outside to blow out saws at multiple workstations...worked fine for a summer or two, but the sun had its way (unpainted) with the plastic...it was actually pretty funny when the crap came apart...I was younger then and thought flying **** and people cringing with fear was quite hilarious :evil:
I think another reason metal is consider premo, is in conducting temperature differences between compressed air and the atmosphere-think drain valves and such condensation type phenom I think
Does anything happen to me? I take what comes... -Marcus Aurelius
  #93
Old 03-08-2006, 12:07 PM
gagiii
Guest
Posts: n/a
thanks cutter, so other than a line rupture there is no other problem? I was thinking that maybe it had something to do with moisture build up or maybe more trash in the lines. I'll have to think about the fragmentational bomb problem. I've had my old shop pipedwith PVC for about 7 years and had no trouble, (yet). Sure is easier and cheaper
thanks again
  #94
Old 03-08-2006, 12:45 PM
Big Al
Guest
Posts: n/a
Another reason is that when the air hose gets tripped over or pulled unexpectedlly it is harder to damage the line. If you use pvc run it into a brass elbow that has ears to secure end. Also heat & vibabration is a problem on some large compressors expecially with high flow rates. I have seen several kinds of plastic pipe melt, expand from excessive heat with pressure added. Not good
  #95
Old 03-08-2006, 08:11 PM
RED caddy's Avatar
10-28-1951 to 4-19-2021
Da Chief
Default The air supply dance
GAGiii, I've had several shops piped with PVC and CPVC and never had a problem. That said, I have seen 2 other guy's that wern't as lucky, one failure was on an outside supply line to a 2 post lift, cut an employee pretty bad with a flying piece of plastic with a brass valve attached. the other was a 2 in. line running along the wall in a leanto shed that took out several hanging lights and a cabinet door,along with the back glass in a customer car.
I'm going with a hard drawn brass tubing system in my new shop, (type L) a perimiter loop with top tap drops every 10 feet and an outside connection by each door, compressor on one end and a 60 gal. volume tank on the other with a "Franzinator" style dryer rig. I guess, like some of the other "Old Dogs" I don't need the drama PVC provides. check out this thread about shop air, http://www.garagejunkies.net/showthr...ight=air+lines That forum has a ton of good info about shop air install's, some of it is mine. well worth the read time before you start building yours. RED
  #96
Old 03-09-2006, 07:55 AM
gagiii
Guest
Posts: n/a
thanks everybody, Ya'll have given me a lot to think about.
  #97
Old 03-13-2006, 08:55 AM
gagiii
Guest
Posts: n/a
Default Freebies
Thought I'd start out with a few pics of some of the free stuff that I've accumulated for the shop.
first is a roll up door
second is the use of this lift
third is the underground wire to go from the meter base to the shop
Name:	shop pics 021206 002.jpg
ID:	10739   Click image for larger version
Name:	shop pics 031206 011.jpg
ID:	10740   Click image for larger version
Name:	shop pics 031206 012.jpg
ID:	10741   Click image for larger version
Name:	shop pics 031206 014.jpg
  #98
Old 03-13-2006, 09:10 AM
gagiii
Guest
Posts: n/a
Default Now let the work begin!!
We went thursday afternoon and picked up the lift. Started work friday morning. My neighbor, Dale, my brother, Clay, and my self. We managed to get things lined out and set 9 trusses the first day.
Name:	shop pics 021206 012.jpg
ID:	10743   Click image for larger version
Name:	shop pics 021206 018.jpg
ID:	10744   Click image for larger version
Name:	shop pics 021206 028.jpg
ID:	10745   Click image for larger version
Name:	shop pics 021206 037.jpg
ID:	10746   Click image for larger version
Name:	shop pics 021206 049.jpg
  #99
Old 03-13-2006, 09:16 AM
gagiii
Guest
Posts: n/a
Default saturday
on saturday we got the last six trusses up and about half the lathe on.
Name:	shop pics 021206 004.jpg
ID:	10748   Click image for larger version
Name:	shop pics 021206 009.jpg
ID:	10749   Click image for larger version
Name:	shop pics 021206 010.jpg
  #100
Old 03-13-2006, 09:19 AM
gagiii
Guest
Posts: n/a
Default sunday
well we finished up the lathing sunday. First pic is my homemade truss brackets
Name:	shop pics 031206 001.jpg
ID:	10751   Click image for larger version
Name:	shop pics 031206 006.jpg
ID:	10752   Click image for larger version
Name:	shop pics 031206 007.jpg
