Old 03-12-2020, 04:50 PM
Well Chris, that's the advantage of a building or plumbing code.
That would never pass here and so no one would do that.
I went overkill on the drain lines last summer, and basically every elbow is a Y clean-out
Have you considered adding a clean-out?
They have state codes for septic tank installation which do require a clean out. Only state approved people are permitted to install septic systems. So much for codes.
I may find some gullible teenager to dig down 5' x 3' wide then I will do that. Digging a 5' deep trench is not on my bucket list.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 03-12-2020, 05:20 PM
Time to go to the resource pile and fab up a back hoe for Scott’s new tractor. You have plenty of time being retired, right?
Old 03-12-2020, 07:11 PM
Ironman Ironman is online now
Not on my bucket list either....oh wait...I can do that with my mini-X
I keep finding more and more for it to do.
Good that the state has some standards, but they are sliding by with the approved installers. Better that anyone can install and then be inspected. That lets homeowners do it as well.
Thomas Sowell
Old 03-12-2020, 08:12 PM
He did ask about a backhoe, but my advise was hire someone if the need came up.
B biggest
I idot
D democrats
E ever
N nominated
Old 03-12-2020, 08:38 PM
Good advice, he might go gold mining if he had a backhoe
He has enough on his plate.
Thomas Sowell
Old 03-13-2020, 02:34 AM
If you get some kid to do it. Have a trench box ready . We lost one 1 1 miles away last week with a trench collapse .
Old 03-16-2020, 07:06 PM
Scott needed a 16' long 10" diameter culvert for his driveway and I suggested a used 10" oil field pipe. Finally found a source but it came in 2 pieces. A little cutting and grinding on one end of each pipe and some welding and now he has a 21' culvert. The septic people are installing it and then running in the gravel for his driveway.
Ran the root with 1/8" 6010 and a cap of 3/32" 7018. Will hold a cement truck now. Welds ran OK for an old blind guy.
ID:	155174   Click image for larger version
ID:	155175   Click image for larger version
B biggest
I idot
D democrats
E ever
N nominated
Old 03-16-2020, 07:16 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
The weld looks nice, but if you want insurance on it, weld a 2"-4" strap around it to give it a little extra.
Old 03-16-2020, 08:17 PM
Will it pass x-ray? Lots of pressure in it.
Old 03-16-2020, 08:30 PM
Tim KS's Avatar
No pressure allowed there, but I was wondering of 21' is enough length. Well I guess if someone drags a trailer over the end of it, it should be stout enough not to bend it down. We always use at least 30' here for culverts.
