Old 11-12-2016, 10:19 AM
Default What is this tool?
I guess it is for pipe fitting but it seems to be made for a specific application, does anybody know what? Organizing the shop here and am wondering what to do with this thing.
An extractor on one leg and what looks to be a 1/8" pipe thread chaser on the other. The other two are what looks to be a spanner and a twelve point socket.
Its Okay to talk about what is wrong with society and environment. Behavior that will mitigate these problems will get you shunned.
Old 11-12-2016, 10:33 AM
tackit's Avatar
tackit tackit is offline
It looks to me like a truck tire size valve stem tool.
Old 11-12-2016, 01:08 PM
4-way grease fitting tool.
Old 11-12-2016, 01:27 PM
Yup, tire valve stem repair tool of some sort. Depending on size it could be for car/truck stems or it could be used on off-highway tires that use fluid for weight...
Old 11-12-2016, 02:00 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
I think this ^^^ is correct. It looks similar to a tire stem tool, but tire valve stems on all the tires I've ever worked on are the same size whether they are car, truck or tractor tires.....which is smaller than what this tool looks like.
Old 11-12-2016, 02:09 PM
Looks to be a four way grease fitting tool. Used to replace fittings and remove broken fittings and repair inside threads.
Old 11-12-2016, 03:53 PM
I learned something.. I would have thought it a tire valve stem tool also..
I could use one of those for grease fittings.. Super handy to have.. I betcha..
_________________
Jennifer
My google+ page
DoALL 36"
Old 11-12-2016, 06:39 PM
dpaulson's Avatar
dpaulson dpaulson is offline
On some industrial equipment (my Hyundai wheel loader is one of them) has large valve stems. You need an adapter to put air into them.
I thought that I was wrong once, but I was mistaken.
David
Old 11-12-2016, 07:26 PM
Tim KS's Avatar
Dave, I don't doubt that there is some bigger stuff (stems) out there to air tires up with. Some of those huge tires would take all day to air up without them. JUst saying what I worked on was normal for my area.
Old 11-17-2016, 09:25 PM
wayne64's Avatar
wayne64 wayne64 is offline
The give away is the one cut on the tool for right angle grease fittings. Also the one other end is much more like an Ez-out for a snapped off fitting.
JMO from the old guy that even has a special tool to loosen radiator pet cock drains.
