Old 10-16-2016, 01:45 PM
Default Missing gear tooth
Started the disassembly of the lathe to replace the gear with the missing tooth. Got down to the removal of the shafts that hold the gears. Removed the set screw but the shaft does not move when tapped with a hammer.
Called the guy I bought the lathe from, since he removed the shafts a year before I bought it. A shaft was bent and he straightened it. He will be over in a half hour.
Hopefully, he can give me the secret to remove the shafts.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 02:25 PM
Scotts Scotts is offline
Or you could have a set screw that did not have a flat under it on the shaft and raised a burr up you have to shear off when pressing the shaft out.
Old 10-16-2016, 03:53 PM
Got the gear out!!!
The gear is 32 teeth on the large one and 16 on the small one. Bore size is 16 mm. Thickness is 18.95 mm. OD of the large gear is 59.52 mm and the small one is 31.25 mm. I expect the od sizes are a little bigger than I have listed due to gear wear.
This is a Taiwan made Husky PC 36 lathe. So who has one of these out in their shop? I will post this info on some other sites as well as here to see if I can pick up a good used gear. If that does not pan out I expect it will be some shopping around to see if I can get a new gear somewhere.
ID:	136121   Click image for larger version
ID:	136122   Click image for larger version
ID:	136123   Click image for larger version
ID:	136124   Click image for larger version
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 03:59 PM
Last pics. The gear has a copper sleeve in it.
ID:	136126   Click image for larger version
ID:	136127   Click image for larger version
ID:	136128   Click image for larger version
ID:	136129   Click image for larger version
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 04:02 PM
MarkBall2's Avatar
I replaced the compound gear (32/16) on Willy 3 times before I got smart.
Ordered a 32 tooth gear from Boston Gear. Ordered a 16 tooth spur gear from Boston gear. 32 tooth didn't have a shoulder, the 16 tooth did.
Bored the 32 tooth gear to fit the shoulder on the 16 tooth gear, pressed together & welded the shoulder inside the 32 tooth gear. Faced the weld off & it's now up & running once again.
I ordered my gears through Amazon, I think I spent a total of around $42.00 for both.
Might check online for replacements.
Mark
Hobart Handler 175
Chicago Electric 165A DC TIG
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Harbor Freight Tubing Roller
Craftsman 12 x 36 lathe
Papa Lion's Gate Build
Old 10-16-2016, 04:04 PM
Turned out the shaft was a two piece shaft. Used my pocket knife to pry it out a little and grabbed it with a pair of channel locks and it came out easy.
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 06:17 PM
So how do you measure the gear pitch?
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 06:29 PM
In the third pic on post 4 you can see evidence of two pins that may have been used to press the two gears together.
B biggest
I idot
D democrats
E ever
N nominated
Old 10-16-2016, 07:34 PM
It sure looks like that is the case that the two gears are pinned together. If you get the same od and the same number of teeth it should be a perfect match. There are avalable pitch guages for gears although I have no idea where to find them. But the right od and number of teeth should get the right one.
Old 10-16-2016, 07:39 PM
I think Shade had a line on a gear man
