Old 06-23-2005, 12:42 AM
metalneck78
Guest
Posts: n/a
Default fluxcore vs solid wire
Why is it you can weld thicker metal with flux core than with solid mig wire? I have one of the portable Lincoln 170 amp mig welders & have to change from solid to fluxcore when I need to weld thick steel plate.
Old 06-23-2005, 01:29 AM
Mostly because the shielding gas cools the metal at the same time the arc is trying to melt it.
Old 06-23-2005, 01:36 AM
X-ray's Avatar
X-ray X-ray is offline
Dont know if this will help or confuse, but it will give you something to read: http://www.weldreality.com/discussio...asp?PostID=241
Looking foward to what the welding hoodlums have to say about this solid vs. flux core topic
Oops, danga your fast Cutter
Old 06-23-2005, 01:49 AM
Franz Franz is offline
Banned
Fluxcore and MIG are actually different processes done by the same machine.
Fluxcore is very similar to stick, with the difference being the flux is inside the electrode rather than on the outside of the electrode as it is in stick. The flux allows the wire to act differently than wire within a gas shield.
Also, there is definitely a lot less depositable metal in a foot of .035 fluxcore than there is in a foot of .035 solid wire. Less metal means the same amount of electrical power in the arc gives you more heat. More heat means you can deposit more metal, and dig deeper, even if it takes more feet of wire to do it.
Old 06-23-2005, 08:45 AM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
Didn't I read somewhere, not sure where, that flux core was closer to spray transfer with solid wire than short circuit?? Or did I make the coffee too strong this morning?
Don
Old 06-23-2005, 09:21 AM
metalneck78
Guest
Posts: n/a
Thanks for the help, think I sorta understand how it works now. Looks like I need a bigger machine, or keep switching out my wire. Makes sence to me now why I have to weld much slower when using fluxcore.
Old 06-23-2005, 09:36 AM
JTMcC. JTMcC. is offline
Current density (the ratio of current to the cross sectional area of the wire), the resistance heating of the relative (compared to solid wire) small/thin wire results in higher deposition rate. And the small cross section current path makes the arc stream assume a narrower shape, that results in more penetration.
JTMcC.
Some days you eat the bear. And some days the bear eats you.
Old 06-23-2005, 09:47 AM
fatfrank fatfrank is offline
Pit Boss
Kind of on the same topic. I have just been running flux core in my HH175 lately because I can make solid welds without grinding all the mill scale off my joints. If I do get a more powerful mig will I be able to burn through mill scale on new metal with solid wire? If I won't be able to, I probly won't upgrade, I'll just keep running fluxcore in my HH175
Old 06-23-2005, 10:33 AM
Banned
Frank, when you get a welder with higher capacity, you'll be amazed what you can burn thru. Of course, you'll need to modify your techniques, or learn to dial it back and fill holes.
Old 06-23-2005, 11:13 AM
Pit Boss
Franz............you trying to say something about my fit-up techniques?
