Old 01-23-2005, 04:12 PM
SNAFU SNAFU is offline
Default new jib cranes
After having surgery this summer, and being restricted on lifting, I decided it was time to make some jib cranes to handle stuff in the shop. This is something I should have done years ago, but when you are healthy, you just don't really think about grabbing somethin and throwin it up on a table.
This one is made from 3" channel upright, and 4" channel turned back to back for the beam. (trying to use up leftover junk)
A new low profile trolley and a 150 pound air hoist that I had layin around completes the project. A dynamometer test rates it @ 375 pounds, with a small abount of deflection from the 3" channel. The 'bearings' are 4" round tubing welded to 1/2 X 4 X 8" angle and fastened to a 6 X 6 post with all thread clamped on both sides of the post. Greased her up and dropped it in place...
Old 01-23-2005, 04:40 PM
7018's Avatar
7018 7018 is offline
Send a message via Yahoo to 7018
Very nice looking SNAFU,I've been thinking about that myself,I'll be 60 on the frist of Feb.And not as strong as I used to be.I've been looking at the HF electric 110 units.They mite do the job to.Any you did a real nice job on the one you built.
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
top of jib
Old 01-23-2005, 04:41 PM
and back of post
Old 01-23-2005, 04:49 PM
This is a heavier duty model that is attached to a boring mill. It has a 1 ton dayton air hoist and was built using and old 3" line boring bar that I was saving for this purpose. Again, 4" channel welded back to back for the beam. 4 - 7/8" bolts holds it in place.
I know, it needs another coat of paint...
Old 01-23-2005, 04:50 PM
base of jib
Old 01-23-2005, 04:51 PM
top view with bearings
Old 01-23-2005, 05:58 PM
One of those things thats always in the back of your mind, but never have time to do...
Old 01-23-2005, 06:59 PM
7018's Avatar
Very nice but how much can you pick up on those bearings?
Old 01-23-2005, 07:05 PM
Well, the pillow block type bottomed out the dyno @ 1150# , plus thats ALL the hoist would do...
(I was standing behind the machine and holding the remote pendant when this test took place )
