Old 08-06-2022, 02:03 PM
digr digr is online now
Tomorrow is the day I pre mitered the corners hoping for no gaps
ID:	165399   Click image for larger version
Old 08-06-2022, 06:10 PM
Looks great.
How did you do the bends?
Old 08-06-2022, 07:00 PM
Banned
Ummm no it does not, I can prove it... come over and I will show you on my container.
Corten is known as the rusting steel.
Maybe the recipe or name has changed ?
Old 08-06-2022, 07:52 PM
Looks great.
Thank's I was able to do the short bends in my brake but hat to slice, heat and bend the back.
Old 08-06-2022, 08:47 PM
Or it was just marketing...
Old 08-06-2022, 10:06 PM
Not exactly Ron. Rust yes, but there is a purpose to the rust.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 08-07-2022, 09:06 AM
Like I said come see the rust through holes in my container that have been patched...
Old 08-08-2022, 08:43 AM
JBFab JBFab is offline
Alright, Corten is a brand name for ASTM A588 Weathering steel. A588 is indeed an HSLA grade, but not all HSLA is A588 (or weathering steel for that matter). A588 surface rusts very quickly, but that rust sort of encapsulates the steel beneath it slowing down further rusting. You won't see sheets of rust flaking off of A588. It's commonly used on RR bridges, not just because of the added yield strength over conventional A992, but because they don't have to paint it. Also, if you're going to use A588 for it's weathering properties, you ought to use the welding consumables to weld it as well.
Otherwise you're defeating the purpose. Another misconception out there is that HSLA (including A588) is produced to pass yield/tensile test and NOT to a specific chemistry. That is false - they must pass both.
All that being said, the surround looks great Ted! For the application I don't think anything mentioned is going to last any appreciably amount longer than the other with the exception of inconel or 316 stainless, but in that case I'd bet it would crack due to expansion sooner than anything else - maybe not if it's not too restrained.
  #29
Old 08-08-2022, 11:33 AM
It still rusts through.
  #30
Old 08-08-2022, 01:31 PM
chumly2071's Avatar
Urban Gunfighter
Another place Corten is widely used is debris bodies on vacuum trucks and sewer cleaner trucks.
