Old 09-05-2019, 07:32 PM
gimpyrobb's Avatar
Default blown molded cases
I've picked up a Proto 3/4 drive torque wrench for my military vehicles (primarily). I didn't realize all the options for torque wrenches till recently, but thats another story. Anyhoo, the case the tw came in is the correct case, but its in rough shape. 2 of the 3 latches are gone and the last one doesn't hold very well. I'm thinking I will melt or glue some velcro to the case so I can make sure it stays closed, but I figured I'd ask what you all do for your cases.
ID:	152093   Click image for larger version
Old 09-06-2019, 06:36 AM
drill a few holes in it, and stick the straw for can foam inside.
Once filled, maybe you can then use screws to attached some metal latches.
Old 09-06-2019, 07:40 AM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
no bull it's huge!
Find a couple of o rings that fit around the case.
Sent from my Pixel 3 XL using ShopFloorTalk mobile app
Old 09-06-2019, 08:12 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
There is always duct tape.
Old 09-06-2019, 08:24 AM
astronut's Avatar
astronut astronut is offline
Bungee cords wrapped around it?
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 09-06-2019, 08:49 AM
pepi's Avatar
pepi pepi is offline
Works for mailboxes
Would not try to melt/glue anything to the case it will just come off down the road, leaving the case looking worse.
A single strip of Velcro warped around will be an easy on/off.
Store my torque wrench in the rear of a drawer, out of the way and protected.
You may want to set the torque measurement back to 0 to store it, will keep the calibration .
Pep
*** KAG ***
