Old 09-01-2019, 02:00 PM
Can always:
1. set it up for welding
2. Set it up with a toolpost grinder
Old 09-01-2019, 02:23 PM
Consider yourself lucky that you do not live in a machine tool desert like my location. Like they are saying buy it compare sell the lesser rig. I'm probably at least still 2 years out on the machine tool adoption plan much to my dismay.
Old 09-18-2019, 09:45 PM
gimpyrobb's Avatar
Looks like this one might be coming to live with me. Any way to identify before it gets here?
ID:	152258   Click image for larger version
Old 09-18-2019, 10:32 PM
LeBlonde is(was?) a common machine make, no idea if they still exist. I’ve ran a couple, newer than that though.
A serial number, model, size or any other info would help narrow it down a little.
Old 09-18-2019, 11:07 PM
Noting it does not have a compound.
Old 09-19-2019, 12:25 AM
Samcord Samcord is offline
Looks like the US division is in Amelia OH. https://leblondusa.com/category/company-profile/
Old 09-19-2019, 06:48 AM
The clutch lever on top of the headstock screams W&S or B&O.
No tailstock, there probably was the rear turret there.
Look at feed rod.
No threading gears/dial ?
Old 09-19-2019, 07:48 AM
Look at feed rod.
What the title of the thread said.
You don't need that. Just the basics of using a center drill would drive you nuts.
Old 09-19-2019, 08:48 AM
However, you might make one hell of a nice horizontal welding positioner for small projects out of it.
Old 09-19-2019, 08:54 AM
JH35's Avatar
JH35 JH35 is offline
PM sent.
Jeff
Curator of the canned cycles.
