Old 09-01-2019, 11:26 AM
gimpyrobb's Avatar
Default Tell me I don't need it
So I have an atlas 12x36.
I found an Enco 12x36 gearhead lathe with the stand and one chuck for 500. Its got the quick change gears and v ways.
I know I could sell mine for the same amount or more, but is it worth the effort?
gimpyrobb's Avatar
https://cincinnati.craigslist.org/tl...969031604.html
Old 09-01-2019, 11:33 AM
NO!!! I will not tell you that, if it is in descent shape I would go for it, that's a great price IMO. And remember its always nice to have a second lathe
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Go look at it and offer $300...Do you have a way to move it...If not that would be a deal breaker..Cost too much to hire it done...
Old 09-01-2019, 11:42 AM
monckywrench's Avatar
trust but verify
It's easy and safe to move machine tools without a rigger if you plan first. I set up this move for a friend with some scrap channel and pipe. His borrowed trailer and some of the floor it had to traverse was decayed wood so I went with pipe skids instead of wheels to spread the load. Attached skids are more stable by far than dangerous skates.
ID:	152041   Click image for larger version
ID:	152042   Click image for larger version
Name:	Bridging weak floor.jpg
ID:	152043   Click image for larger version
Name:	MM tiedown.jpg
Old 09-01-2019, 11:46 AM
trust but verify
More pics. We bring my "kit" of steel, channel with (bolted for easy relocation or to skid instead of roll) casters, pipe, etc and 6" angle grinder (for cutting with zip disks) drill, jacks etc. The lathe was loaded by fork lift or I'd have put bases beneath it at the start.
ID:	152045   Click image for larger version
ID:	152046   Click image for larger version
Name:	Perpendicular pipe roller pivot.jpg
Old 09-01-2019, 11:56 AM
trust but verify
Quality allthread works perfectly for raising machine tools. I left the angle beneath the mill to clear a pallet jack and to suit my height. The channel with casters was placed above the lathe and mill bases then I drew 'em up into place with the allthread.
That's far safer than a forklift, works indoors, and can't tip. We're done three lathes, four mills, a surface grinder, and two tool and cutter grinders so far. For something big enough I can modify mobile home, truck or trailer axles. That also means we can winch loads across gravel or dirt. While I have truck winches it's usually more convenient to hand winch. We use snatch blocks to winch from any position.
YOU NEED IT.
Name:	BP in ISO.jpg
ID:	152048   Click image for larger version
Name:	Straddle dolly lathe movement.jpg
ID:	152049   Click image for larger version
Name:	Bport straddle dolly.jpg
Old 09-01-2019, 12:01 PM
Run, don't walk, and bring money!!!!
Old 09-01-2019, 12:40 PM
gimpyrobb's Avatar
I talked with some guys local to me. while it is a good deal, its not worth the time and effort. I work like 60hrs a week and have ZERO room for 2 lathes. It would be too much effort at this time for my situation.
I figured I would get encouraged by the kids in the clubhouse
Old 09-01-2019, 12:47 PM
In your situation, I would buy it, see if you can get the price lower,
bring it home and compare the 2 you have, keep the better one or
the one you like and sell the other at a profit.
If you work 60 hours that leaves you 108 hours to sort shit out.
