Rest In Peace Cutter
Old 08-27-2019, 04:03 PM
Camaro Zach's Avatar
Default 2 speed motor wiring
A friend’s dad gave me this fan a year or so ago that was missing the motor. I finally found a suitable 1/2 horse 2 speed motor in an old washing machine to cobble together.
I have been reading and researching the wiring for the last two weeks but I still can’t wrap my head around it
I included a picture of how I have it wired right now. It starts and runs but when you shut it off the motor still tries to turn at a slow rpm. Until you unplug the cord or unplug the capacitor.
Thanks
Zach
ID:	151960   Click image for larger version
ID:	151961   Click image for larger version
ID:	151962   Click image for larger version
ID:	151963   Click image for larger version
Buggy
Old 08-27-2019, 07:42 PM
Looks like you should put the capacitor wire on the other side of the switch to cut the power to it.
Old 08-27-2019, 07:54 PM
I agree and I think it would fix the problem but without going with a DPDT switch wouldn’t it overheat the capacitor using it to power the run windings?
(I’m hoping there is a way to achieve high/low function of the motor with only a SPDT switch if my wiring checks out) maybe I am crazy
Edit: it would work on a single speed with the capacitor after the switch but with the dual speed switch would it back feed to both the high/low windings at the same time? or does the centrifugal switch (pictured above) mechanically eliminate that possibility?
Buggy
Old 08-27-2019, 08:16 PM
Someone will be along that should know. I know on a furnace blower the white is ground and the black is hot and what ever colored wire you put to the black gives you another speed and the capacitor is wired separately.
Old 08-27-2019, 08:51 PM
On some motors I have the high(er) speed(s) are provided by the capacitor and I suspect that's what's going on there. The capacitor might be the run capacitor for high speed.
I have an antique Edison 3 or 4 speed "house" fan in my bedroom that is entirely dependent on the capacitor for speed selection.
Having said that, I am certainly no motor guru. . I like to wait for scotts or someone to dissect the motor questions.
Old 08-27-2019, 11:20 PM
do you know the name of the washing machine?
do a search on the motors model number.
Old 08-27-2019, 11:48 PM
Scotts Scotts is online now
It’s late and I’m out in grain valley mo.
It’s a little difficult on my phone.
I found this.
http://www.applianceaid.com/general-...ample_diagrams
There are a selection of options in the diagrams.
Back and forth on the phone is not going well for me tonight.
Old 08-28-2019, 12:35 AM
Is this close?
Old 08-28-2019, 05:56 PM
The centrifugal switch removes the "cap and start winding" from power once the motor gets up to 80% rpm, only used for starting otherwise they burn up.
assuming you have the centrifugal switch wired as need be, you need to add an on/off switch.
I'm not sure what would happen if you switch the hi/lo switch while the motor is running,
so only select hi or low when the power is off AND motor at a "FULL" full stop!
Old 08-28-2019, 06:13 PM
Hey I was right
