Old 08-20-2019, 01:41 AM
...We are going to be at Cam's place halfway between Red Deer and Calgary...
Yup, Cam's place is "just down the road" from Gerry's...
Old 08-20-2019, 06:45 AM
camdigger's Avatar
Roving Reporter
Hmm,tomorrows tuesday right?
i have to kill some time..
If you turn east at the jct of Hwy 93 and 11, you'd still be nearly 3 hours away.. There's lots of parking space here for your outfit. Not all of it perfectly level.
I can pm you details.....
Old 08-20-2019, 10:39 AM
randydupree's Avatar
Why, Hell Yes!
Looks like i will pass on this trip,too many days between now and Sat.
So you guys enjoy.
Carol and i have both run out of our meds,and we have to go to the states to refill.
Thanks.
Old 08-20-2019, 03:24 PM
If Ironman doesn't pan out you might consider a hole saw.
Old 08-21-2019, 06:12 PM
camdigger's Avatar
Roving Reporter
So you have a big plow or something to drill the holes in to install a replaceable cutting edge?
This is the project I am putting cutting edges on. It is a shameless copy of a Duragrader, among others. The angle laying across the top is one of two that will eventually be mounted roughly even with the bottom of the side panels. They will be the backing/support for the two cutting edges.
ID:	151894   Click image for larger version
Old 08-21-2019, 08:34 PM
Scotts Scotts is offline
Thanks for the pictures.
I never have used anything like that.
Best of luck with the hole drilling.
Old 08-22-2019, 01:16 AM
Cam, unless those are old pics why don't you precut your blade mount angle, mark the hole locations and pre-drill the holes BEFORE you weld the angles in place?
Also, if you're doing very much of that type stuff (as I do) it wouldn't take very long for that kit I linked to earlier to make you glad you got it.
I have a top end Hougen mag drill and cutters from 1/2" up to 1-1/2", but I got so spoiled by how easy holes are with annular cutters that I got that small kit - now even holes that're too small for a mag drill are just as easy using a simple battery drill.
It's a piece of cake to duplicate a hole pattern like you're doing, all you need is a transfer punch - clamp the cutting edge to the piece you want it mounted on, transfer punch all the hole locations, then the built-in pointed pilot snaps into your punch mark and every hole is exactly where it needs to be... Steve
Old 08-22-2019, 06:51 AM
camdigger's Avatar
Roving Reporter
The biggest reason I have not drilled the angles yet is the fact that I do not yet have the cutting edges in hand. I have to wait till Friday to pick them up.
The other reason is I don't like putting stuff that awkward in my drill press, and it is difficult to do in my milldrill due to space.
To me, drilling these in place is the easier option. If using a mag drill, it will make little difference if the assembly is welded up or the angle simply laying naked on a bench. The blade assembly will be bolted to the side plates with one set of holes slotted to allow for cutting edge wear.
I will have to turn up a transfer punch. The specs I saw for the cutting edge specify an unusual clearance hole diameter. Turning up a transfer punch will be a simple lathe job. I have 1" drill rod in stock.
I don't do enough of this to justify annular cutters yet. One job like this in three years, does not make it worthwhile so twist drills would have to do if I was completely left to my own resources.
Old 08-22-2019, 10:38 AM
Or you can wrap tape around the closest fit punch you have and it will be as close as you will need. after the first hole is pilot drilled to to about 1/2 you can fabricate a stop for a reaction bar to prevent the drill from turning and hitting you.
Old 08-22-2019, 11:27 AM
...Or you can wrap tape around the closest fit punch you have and it will be as close as you will need...
Done that lots of times too--quick and dirty but it works. I've made lots of one-off transfer punches on the lathe as well. Depends on what kind of a mood I'm in--I like to play on the lathe...
