Rest In Peace Cutter
Old 05-10-2019, 05:39 PM
NOBLNG NOBLNG is offline
Default Free Anvil
My neighbor is moving and gave me this anvil. I realize after a short google search that it is a low quality unit, however up until now I have been using the back of sliding jaw on my vise as a mini anvil...so free is well worth it. It looks like the horn has been repaired at some point but I am really wondering about the uh... ugliness on the body. Does it look like a repair, or a really bad casting. I will sand blast the area when I get time to have a better look. Opinions anyone? Thanks!
ID:	150693   Click image for larger version
ID:	150694   Click image for larger version
ID:	150695   Click image for larger version
Old 05-10-2019, 06:36 PM
I think you summed up the situation in your description. Free, did not have an anvil before would seem to add up to a minimum %100 improvement over your previous status
Old 05-10-2019, 07:15 PM
I would lean toward bad casting, but the price was fair.
Old 05-10-2019, 08:19 PM
Looks like a poor casting. Likely a sand mold and the sand wasn’t filled/packed properly.
Old 05-10-2019, 08:46 PM
A little welding can fix up the casting issue. Price was right!!!!!
Woodrow Wilson
Old 05-11-2019, 12:19 AM
Any Anvil is better than no anvil .I vote casting .
Old 05-11-2019, 08:10 AM
Thanks all. I think I will sandblast it to get a better look first. If it is a bad casting it should be OK to just grind the extra flash off and paint it? I don't think it is worth doing the welding to repair it? Maybe a touch of body filler or epoxy before paint.
Old 05-11-2019, 08:46 AM
Turning down an opportunity to weld????
Woodrow Wilson
Old 05-11-2019, 11:54 AM
I have a Chinesium Olympia 5" vise that they must have used pea gravel for casting sand. They then spread a Bondo-like substance over the outside of the casting, then painted it.
I also have some press plates picked up from HF that were similarly surface treated. This was noted upon first use! I now "protect" the surface with a 6"x6"x1/4" steel plate...
Old 05-11-2019, 12:13 PM
Why on earth would you paint an anvil? You been watching Martha Stewart?
