Old 03-29-2020, 07:30 AM
OZWELDER's Avatar
OZWELDER OZWELDER is offline
Default Intermittent start of Miller Elite digital screen
Hi guys,
I have Miller Elite with an an annoying problem.
One day it will switch on and work and a few days later will not switch on after repeated tries.
Again a few days later it will turn on and the a bit later will not work and so on it goes.
Is this a known Miller Elite shield problem or a common defect?
No I don't know the model or how to indentify the model,but will give a description the insert measures 5 3/16" x 4 1/2"
The control panel is 4 1/4" x 1 1/4" and from the left side is the membrane (as all the buttons are) circular ON button with a rectangular MODE button to the right of that.
Modes available are weld/cutting /grind.
On the right side of the digital screen the are six arrow type buttons for the up and down -shade- sensitivity- and delay, all variable values.
It has had the correct (thickness) Button batteries replaced - the old ones tested the same voltage as the new ones.Contact for batteries inspected and all found to be good.
I am almost to the point of splitting the insert case and inspecting the circuit joints under and magnifying light for cold solder joints.
Are there any suggestions members can offer me as how I may fix the shield?
Thanks
Oz
Ozwelder
May your chooks turn into Emus and kick ya dunny down.
Old 03-29-2020, 10:48 AM
No real suggestions, have one with issues though, will no longer turn on at all. So, following to see what you find out.
Old 03-29-2020, 11:44 AM
Originally Posted by OZWELDER View Post
Hi guys,
Thanks
Oz
Has this got wet or been in the rain at any time?
They all use the same electronics, and I have killed one, not Miller brand, but they are the same under the plastic. It was just a little rain and I shook off the water, but it was dead.
No, I could not fix it, replaced.
FWIW, I left a Milwaukee impact out in the wet and it died on first use the next day, the repair shop said it got wet.
Old 03-29-2020, 11:56 PM
OZWELDER's Avatar
Hi Ironman,
The very opposite,the shield has been looked after all its life.It came with a drawstring bag a gets hung in that in the shed in the shade.
It was working fine the day before yesterday but I got it down and press the blue blazes out of the membrane and got nothing. in another few days if it follows the plan,it will work.
I will wait a few days to see if anything else comes up and open it and inspect it. I shall be looking for a cold solder joint.
In its day it was expensive shield like 350 odd dollars.
Thanks for the replies.
Oz
Ozwelder
Old 03-30-2020, 01:15 AM
OZWELDER's Avatar
Hi Guys,
Its and hour and something later than my last post.
I have just been playing with the module and decided to shine my bright Cree type led torch in to the light receiver/trigger? cells across the bottom.
Well sort of, set the torch ( flashlight to you,I think) on its end and held/ balance the cells over the end of the torch.
Ten seconds of light and press button and yes the bloody digital screen operated.
Woohoo
I am no electronic genius but there will be a way to diagnose this in a step by step manner.
Any thoughts on the way to go?
Oz
Ozwelder
Old 03-30-2020, 01:27 AM
There are probably capacitors attached to the photocells that add a little "boost" to help the photocells work. I've had non-battery hoods that needed a "refresh" under a light source before putting into use so they would function properly. Maybe this is the workaround you need to do before use?
Old 03-30-2020, 08:02 AM
Hi Guys,
Woohoo
Oz
If you do get into the guts of it, check that the photocells are functioning properly and are clean of smoke.
Old 03-30-2020, 11:41 AM
Norm W's Avatar
Norm W Norm W is offline
I have a HF hood that has been working for about 12 years. I hang it in the window so it gets a daily ration of sun light. If it's stupid but it works, it ain't stupid.
Old 03-30-2020, 01:02 PM
...The very opposite,the shield has been looked after all its life.It came with a drawstring bag a gets hung in that in the shed in the shade...
...I have just been playing with the module and decided to shine my bright Cree type led torch in to the light receiver/trigger? cells across the bottom.
Ten seconds of light and press button and yes the bloody digital screen operated...
That might just be the source of your problem. If the helmet is always kept in the dark it might need a boost to get it going. Try hanging it someplace where it gets light all the time and see if the problem goes away...
Old 03-31-2020, 10:43 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
I have the same hood and it needs light to work..When I kept it in the dark it wouldn't work. It works best when used every day...
