Old 03-03-2019, 10:50 AM
gimpyrobb's Avatar
gimpyrobb gimpyrobb is online now
Default Pallet jack troubles
A buddy brought me a pallet jack, says the hydraulic doesn't work. Seems to me, the pressure bleeds off. Is there a safety on these things to keep from overloading? Its rated at 5k and there is no leaking hydraulic fluid but it won't lift 800lbs. Another thought, I'll have to verify its full of fluid first! it was late yesterday and I was worn out from setting up pallet racking. I didn't see a model number or manufacturer on it either.
Old 03-03-2019, 11:03 AM
Scotts Scotts is online now
The piston seal may be bad, If it leaked in the past someone may have filled it and got some trash in it. Some of them have a pump lower and neutral position on the handle for the hydraulics. It could be out of adjustment.
Old 03-05-2019, 10:49 PM
Not trying to go OT but I have a very nicely constructed Roush floor jack. About a month after the warranty was over it leaked out most of its fluid from the main piston seal. There is a hydraulic guy here that "fixed" it for me in exchange for some welding work. Took him 3 months and he gave it back to me with no fluid in it... Anyhow, it has started leaking again...
But yes, check the fluid and have a pan ready in case it pukes out...
Anyone have a source for hydraulic seals and such?
Old 03-05-2019, 10:58 PM
http://herculesus.com/
Is where my shop gets most of our seals.
Old 03-06-2019, 03:36 AM
Do you have a good source like this for automotive seals?
I could sure use a good parts house bypass source...
Old 03-06-2019, 07:58 AM
gimpyrobb's Avatar
I have a place that I've used for years now, Pride seal. Those guys rock.
Typical as of late, I'm working 6 of the 7 days this week. I probably wont get back to this till May the way things are going right now
Old 03-06-2019, 09:02 AM
Time for a seal kit, they usually take common O rings. I don't think this is your problem, but it should be eliminated as a probable cause.
Usually when you have pressure bleeding off, it is because someone lifted something too heavy. Any jack will lift more then it should, like humans.
When the pressure is released high pressure oil will cut a groove in the seat of the release valve and thereafter will leak down.
The valve itself has a cone shaped end on the release screw. It could be the screw, but more likely the brass seat that is damaged.
I have been told that putting the right sized ball bearing in there and tapping with a hammer can repair the cut seat, but I have not tried it. I would rather turn a punch end to the right shape and hit it that way to reshape the seat. That does work.
Aaron Neville
Old 03-06-2019, 01:03 PM
Thanks Brian. I've downloaded the pdfs and will glance through them later...
Old 03-06-2019, 06:23 PM
They stock both standard and metric sizes. We identify seals as we rebuild cylinders and pumps, and then choose the closest fit we can. Sometimes we can’t find an exact match for OEM, then we will try to modify existing parts to take a new size seal, and if that does not work, then we will make new parts that will.
If you can measure the seals you need, you might be able to cross it over to something that will work, if you can’t find seals in the normal stores.
Old 03-06-2019, 06:36 PM
Do they do/make/carry the seals for like automotive axle and hub, rear main for engine type? is what I'm looking for. I have 4 major players in the supply business here available locally for that stuff but always seem to come up empty handed with them for the most part, the only competent guy has sold his business and is gone after 45 years... sad as he knew his stuff by heart when it came to bearings and seals and could always seem to find what a guy needed... nowadays it's a bunch of school kids who can't use a computer for anything but gaming...
pic is example seal type
