Old 02-18-2019, 07:48 PM
SmokinDodge's Avatar
Default New generator engine
We just received the first one of these in the US. 2,800 horsepower at 1,500 rpm, 30,000 pounds.
This engine alone weighs what our biggest V16 engine, genset and skid weigh combined.
There’s nothing on this bastard beside the valve covers a man can pick up.
Old 02-18-2019, 08:25 PM
It does look easy to work on even if you have to use a crane to move the parts.
Harry S. Truman
Old 02-18-2019, 09:35 PM
Sometimes, with a good crane and operators, it can be easier than doing stuff by hand. The crane can hold a part 1/4” above it’s mating piece for much longer than any of the guys can!
Old 02-18-2019, 09:44 PM
Looks like you got a sheet metal brake ready for the tin work What kind of pollution crap do they have?
Old 02-18-2019, 09:49 PM
None that I work on.
This thing runs on cow farts so it actually offsets emissions.
Old 02-18-2019, 10:49 PM
Are those coils and spark plugs? (blue wires)
Old 02-18-2019, 10:53 PM
Yup. Spark ignited with prechamber heads.
Old 02-19-2019, 07:25 AM
Who makes this one ?
Pulling rod & main bearing caps is fun....But the hand access covers look pretty large.
How big is the oil sump ?
I'm surprised for what it cost, they only made a wood shipping pallet, not something
made of box tube.
Old 02-19-2019, 08:46 AM
governor-electronic or mechanical? for all that HP it sure doesn't leave much room for the housing/generator mount underneath the intake manifold.
An engine of that size would normally be a SAE#1 or bigger..kinda looks like a smallish #3 FWIW
Not Enough Room
Old 02-19-2019, 09:10 AM
I saw that too, but it might be an auxiliary drive.
The other end might be the main flange.
