Old 02-24-2006, 06:27 PM
beasjc's Avatar
beasjc beasjc is offline
Default tig conversion
hey everybody! I was wondering if anybody could help me figure out how to put a thumb amp control on my tig. It's the cheap Harbor freight one. I would like to put a thumb switch on it, but as far as I know, there is not one made for it. The amp dial on the front has three wires going to it. Could I find a three wire control and wire it in? I know you can't tell me to just do it because of safety, but I have a little sense, so if something doesn't sound right, I won't try it. If the parts are available, and it can be done, I think I am able to do the work, no problem. I just don't know about the parts. Any suggestions, idea's?
http://www.harborfreight.com/cpi/cta...emnumber=91811
ID:	10041   Click image for larger version
ID:	10042   Click image for larger version
beas
Old 02-24-2006, 07:22 PM
First, what do you think of the welder ? good/bad ?
What's the duty cycle on the machine ?
What about making a foot control ?
What's all the markings on the heat control ?
Do you have a volt/ohm meter ?
Old 02-24-2006, 10:53 PM
beasjc's Avatar
The welder does what it should for what I paid for it, how I treat it, and that I bought it to learn tig. It's scratch start, dc only, but I can tig steel, which I couldn't do before. It is 5 to 130 amps, divisions of 1 through 10 on the dial. It is a 35% duty cycle, and I hit it a few times in the heat of the summer, but not often. Then again, I'm not really pushing it either. A foot control would be ok, but I think I would rather have hand control. I'm rarely sitting at a bench, and hand control seems like it would be more comfortable. Yes, I have a volt/ohm meter. If you have anymore questions, ask away. I really want amp control!!
beas
Old 02-24-2006, 11:43 PM
I down loaded the manual on that machine, and the amperage is controlle via a potentiometer. You would have to fine another potentiometer of the same specifictions and the be able to isolate the orignial from the circuit and feed you new one you mount on the torch. You might get lucky and a standard finger control may have the same specs as the one in the machine. You will also have to install a jack or hard wire it yourself. It can be done but I would not call it easy.
Old 02-25-2006, 12:10 AM
See picture.
I need all the markings off the control like the ones in the pix.
They may be printed on the side and not the back, like in my pix.
Name:	C1 P2240230.JPG
Old 02-25-2006, 12:13 AM
From my point of view, matching it should be easy, wiring it (3 wires?) should be a piece of cake.
Mounting it so it would be easy to manipulate would be the tricky part.
Old 02-25-2006, 06:16 AM
Tom Zachman's Avatar
Dodge City Marshal
Disconnect the original pot and measure the resistance between the two outside lugs. Specify that number with "linear taper" and not Audio taper. "Oil filled" would keep contamination away from the wiper.
New sig line:
Old 02-25-2006, 10:41 AM
beasjc's Avatar
Thanks for the help so far. On the circuit board, it has
f1647-1
a4942
PH03.04
on the meter is a sticker that has
HA
B10K
here are some pics of it, and since how do I like the machine was asked, here is a picture of the lincoln Biplane, that I learned to tig while making(can you say grey hair now!)
pics are not real good, I'm working on that!
ID:	10064   Click image for larger version
ID:	10065   Click image for larger version
beas
Old 02-25-2006, 11:29 AM
Sberry's Avatar
Sberry Sberry is offline
GOD of Strawberries!!!
This is a good idea, we hear a lot of half assed things about modifying welders but this control for that machine is excellent. Its cheap and ought to work. Well worth the time and cost to dodder around with.
Old 02-25-2006, 02:59 PM
HA
B10K
Your saying "Meter",
Your Picture 007 shows a "Control" I assume its the heat control.
Is the numbers from a sticker on the "Control", or are you talking about your volt/ohm "meter" ?
I want any and all numbers off the "Control"
I dont want to assume anything.
