Old 10-23-2018, 08:39 PM
Put your mag drill on the compound and mill the flats
That sounds worth a try. Thanks for the idea.
“Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves"
William Pitt (the Younger), Speech in the House of Commons, November 18, 1783
Old 10-25-2018, 03:43 PM
Git the indexing drill jig finished today. Made a spacer from a piece of 1 1/2" pipe and welded a 1/2" thick plug in one end so I could use the existing tool holder bolt instead of buying a new bolt. Painted the assembly with rust reformer. Welded a short piece of 1/4" plate to the bottom side of the 1/2" x 4" FB so it would be at the right spindle center height to mount the tool holder. The whole affair was very rigid. Drilled the spider holes with it. Worked real slick. Threaded to end of the 3/8" rod in the lathe for the 3/8" chuck.
ID:	147833   Click image for larger version
ID:	147834   Click image for larger version
ID:	147835   Click image for larger version
ID:	147836   Click image for larger version
Old 10-27-2018, 08:53 AM
:-) That is why he only used 3 holes in the spider. His "INDEXER" only has 3 stops. :-)
...lew...
Old 10-27-2018, 09:34 PM
...lew...
I could use the 4 jaw chuck and get four if needed.
Old 10-28-2018, 09:59 AM
Being a fan of Joe Py, I had to see what he says about indexing.
On the cheap is good.
Aaron Neville
Old 10-28-2018, 12:21 PM
Those collet blocks are the ticket for a lot of different things. I rarely need to index more than six positions so, although I have one, I rarely use my rotary table. They can be used for indexing two or four flats on a shaft, for aligning two keyways or for putting a hex on the end of a shaft if you want to turn it with a ratchet instead of an ordinary wrench...
Copyright ©2000 - 2018, vBulletin Solutions Inc.
