Small drill I found at work today.
OMG those are small. Can't imagine why we would even stock them as building 1 has no machining equipment. I know that's too small for a cordless drill to get a grip on. Just posting as I've never seen one that small, carry on! |
You can get a pin drill holder for those. Used for cleaning carburetor jets, particularly on small motorcycles. The entire pin drill holder can be put in a regular drill motor.
Somewhere I have an index for 61-80. I think I’ve only used one drill out of it.
About a year ago, a customer came in with some small parts for a freezing tool for freezing water lines so they can do repairs. I think the hole ended up being a number 78. They had bought some new nozzles, but the company shipped ones that the hole was not drilled in them.
They replaced them, but my customer brought the not finished one to me to see if I might be able to put that small hole in. Challenge accepted. I got boss to order me a set of 70-80 drills with a holder. I made a slip tube for the holder so I could install it in my tailstock chuck, and just hold the holder/ drill with my fingers to drill with. I wanted the light feedback from fingers. I turned the lathe (20x84 summit) to its highest speed of 1500 RPMs, and with my butt puckering at the high pitch sound from running a big chuck that fast, drilled all the nozzles for him. Sent from my iPhone using Tapatalk
What gets me about those small drills is how they manage to make the flutes and grind the cutting edges on something that small. The smallest commonly found drill is a #80 which has a diameter of .0135" but Machinery's Handbook actually lists drills down to a #97 which is .0059" in diameter. I've looked at some of those small drills with a microscope and it's amazing how perfectly formed they are...
Maybe one or two of these need to head home... |
We used those when I was a burner in the fab shop for saving torch tips that got a little buggered up.
Mikuni jets are different, they are sized by flow rate, a given pressure at a given amount of time. A #150 main jet flows 1.5cc/minute (or so I remember). I don't know what pressure/temperature they used, beyond my pay grade. A few more years, you will be hard pressed to find somebody that knows how to work on carburetors. Kind of like points, or magnetos.
Director of Sarcasm (by appointment) Director of Innuendo (by suggestion) |
Speaking of carbs, I have to pull them off my XL350 (1-2 progressive). Needles are leaking. Probably time to install the petcock rebuild kit while I'm at it...
When I first got the little cnc mill I ordered some sample tooling parts that came with some itty-bitty drills. Even using the machine I managed to screw them up with a quickness.
