New Fixture table!
I found a friend with a laser cutter that said if I paid for the steel, and traded him some old Willys jeep parts, he'd cut me some holes in it for me. He said he could cut 1/2" steel with his laser.
Now... I like my 1" top, but I've really never had a time where I thought, "Golly, I'm glad my top is 1" thick!" so I took him up on his offer and had him cut a 48"x 72" sheet of 1/2" thick steel with (805) 5/8" holes set on a 2" grid pattern. After about a week, he told me it was done. I pulled off the 1" thick top to make room for the new sheet. Last edited by Scratch; 07-17-2024 at 10:58 PM. |
Using a skid steer with forks, the new top was on in a jiffy!
I have actually lost sleep over this next part... I really wanted to use Fireball fixtures. I love their tooth block design and the 2 pin design of their fence blocks, but I was literally terrified that their fence blocks weren't going to fit because the holes were just a little bit off. I had heard Jason from Fireball Tools mention once that spacing should be in the +/-.002 range, and my laser guy says his table has a tolerance of about +/-.005, so I was very worried that I was going to have a table that would have great clamping abilities, but not be able to use the Fireball 2 pin fence blocks (Well, with two pins at least) I also really like their larger fence blocks and the ability to use them in a 45 degree setup, but again... terrified they wouldn't work.
So first test... do I really have a 2" grid pattern.........? Yes! they fit great! |
Next test, can I use the Fireball Tools long fence blocks, set at a 45 degree angle.......?
Yes! They fit great also! I guess lasers do actually work! |
I'm assuming these specific fixtures are going to be my bread and butter fixtures for the stuff I'll be making.
Now for flatness. With my old 1" top, it had about a 1/4" gap over the 6' span. I didn't like it, but I made it work. Honestly, if I could make this ANY better than that, I'd be happy. I set my 6' level on the short side of the table. It was nice and flat! Now I didn't get out the feeler gauges, but the level didn't wobble anything noticeable so I was very happy with that.
Over the 6' length though, things were different. There was almost an 1/8" of wobble on the level. Many years ago, I tried to pull my old 1" sheet with clamps and bolts, but it wouldn't budge. Now with this 1/2" table top, I was hoping I could pull this sheet into place if I needed to, so I tried putting a clamp underneath and was able to pull it perfectly into place! Again... I didn't get out the feeler gauges, but if my 6' level looks good, I'm happy! I’ll weld on a nut or something to make it more permanent. |
I also made a rolling cart for my fixtures and clamps. I looked at a bunch of different designs for storage and really liked the design Fireball had, so I based it on their design. I don't have too many fixtures yet, but I hope to change that in the future.
New Fixture table!
Nice work! I’ve been thinking, dreaming about a fixture table myself.
I was thinking about Jason’s first design using 1’x1’ plates that are spaced a couple inches apart thinking how it would work out for me. I guess pros and cons both ways. I have a 1” steel table 6’x 12’ in my shop. Most of it is a catch all and at the moment only 2/3 is available. And it has a considerable bow in it. I’ve been thinking about making a new base for it and try to get it straightened. Plus I don’t like the existing base since they made it overhang only 2”, making it tough to clamp down to. And I may start drilling holes in it for a fixture table. I might make my own drilling template. I’m frugal that way, and figured that’s why I have invested in my hobby tools. Getting my retirement home shop set up well before I actually retire someday from the day job. Last year I bought some of the Fireball mega squares. I have liked them and would like to invest in more of his stuff. Sent from my iPhone using Tapatalk
Very nice!!!!
Drawing by Smartdraw |
