Tool Grip Material
"There are three and only three ways to reform our Congressional legislation, familiarly called, the ballot box, the jury box, and the cartridge box" (Frederick Douglass) |
Let FAITH be bigger than your FEAR. ***** Pray like everything depends on God, and work like everything depends on you. ***** The world is changed by your example, not by your opinion. --St. Mother Teresa ***** In life it's important to know when to stop arguing with people and simply letting them be wrong. ***** Live like you are dying......because you are. |
Tool Grip Material
I stretched a tight piece of rubber hose over the end of a pair of pliers I use on the lathe to remove swarf. So far has been working about 6 months. I have had the plastic dip type stuff fail in short time before. Probably didn’t put enough layers on.
Brian You don't know what you don't know. "It's what you learn after you know it all that counts." John Wooden Last edited by toprecycler; 06-20-2024 at 07:17 AM. Reason: Add pic |
I've never had much luck with plastidip, but for some reason I keep trying. It's almost like the metal needs some sort of primer to get the initial adhesion going, but I've not found anything that works.
I have had better luck with their 'spray on' products. I've used it on car parts, including the hood of our little Honda Element. Never tried it on tools because it seems that it takes forever to really build up a useful layer that would make a tool grip. Never thought to do an initial coating of the spray, let it cure out, and then dip it though. I sorta quit worrying about it really and now have a drawer full of crap I never use. I've slowly been making the switch to Knipex stuff with the hope that it'll outlast the years/work I have left to do. So far that plan is working well--most of them are in a waxed canvas bag that I can't ever find when I need pliers. |
Several layers of heatshrink tubing?
what about bed liner material. it seems pretty robust to the elements, should hold up ok to pliers usage.
Maybe one other thing to help, if using Bedliner or plastic dip is to rough up the surface with sandpaper, or hard wheel grinder. Give the paint something to stick to.
I haven't personally tried this yet, but 1 should do several small tools.
Dt
Sero Sed Serio Acta non verba |
Thanks for the replies. I tried some of your suggestions and found that I preferred the shrink wrap tube. The Plasti-dip worked OK, but I don't think it is particularly durable. The one place it shined, was overcoating plastic coating that was starting to deteriorate. The big negative to Plasti-dip is the cost. There is a lot of waste. I am curious how long an opened can will last. The shrink wrap is pretty quick and easy. It is also cheap with very little waste. I found that the thicker wall shrink wrap works best. The group pictures show tools coated with Plasti-dip. All were coated twice and some were coated over existing plastic coating. The pictures of the single pliers were done with shrink tubing.
I have ordered some extra thick shrink tubing. I will let y'all know how it works.
"There are three and only three ways to reform our Congressional legislation, familiarly called, the ballot box, the jury box, and the cartridge box" (Frederick Douglass) Last edited by Randyjaco; 06-21-2024 at 08:52 AM. |
Putting my .02 in, having never used PlastiDip, I would clean the handles with Brakleen to remove ALL the residue before applying. It won't help the toughness of the coatings, but it will increase the grip.
