Old 02-21-2024, 06:57 PM
gimpyrobb's Avatar
Default Picked up a troybilt tiller!
Might epoxy it(carb) to verify it runs first, seems to be in good shape.
ID:	170198   Click image for larger version
ID:	170199   Click image for larger version
ID:	170200   Click image for larger version
Old 02-21-2024, 08:24 PM
Nice. if you got for $100, you stole it. I seldom see them less than $500 around here. in any condition. I've got a smaller Pony model and really like it for garden work but its not as good as the bigger models at breaking new ground.
Old 02-25-2024, 08:21 PM
gimpyrobb's Avatar
Well I checked the oils and they looked good. I took the carb off to inspect but haven't got that far yet. I decided to see if it would fire. I have had good luck by soaking a rag in gas and letting the fumes power it.
Never had a backfire set the rag on fire. It scared the dog more than it did me(you'd be surprised how many times I've set myself on fire).
Anyhoo I may pull a carb off another motor, it looks pretty generic.
Old 02-26-2024, 04:58 AM
If it does not want to run right and continue to backfire, possible the flywheel key may be partially sheared.
Old 03-12-2024, 03:23 PM
gimpyrobb's Avatar
Well I took a gamble on a chingchong carb for $20 and she runs like a champ! It was touted as a direct replacement for my carb, it is not. I will need to make some kind of spacer so the choke can be used, but I now have an expensive tiller for cheap. Now I need to replace the muffler and tires. I should be all set for about $200 total.
Old 03-13-2024, 07:50 PM
gimpyrobb's Avatar
Found some new tires on marketplace for $20 each! No they aren't V tread, but I d9nt care.
Now I just need to get the muffler off. I tried a little today and it said " go fuck yourself ". I'll tinker more with it this weekend.
ID:	170345   Click image for larger version
