Old 01-14-2024, 01:44 PM
Swede24 Swede24 is offline
Default Sander won’t start
Hi all, new member with my first post.
I recently purchased a new to me used drum sander. Before purchasing, I insured that the tool worked by having the seller turn it on and run a board through it. Then I drove it home five hours in the back of my pick up. Took it out put it in the shop and plugged it into my extension reel. The unit did not turn on. Next I picked an extension cord off the rack and plugged it into a different outlet and it turned on immediately. That was the last time it turned on. In the last few hours I’ve plugged it into multiple different outlets with and without extension cords. The unit just won’t turn on. I’ve taken off the panels looked for obvious electrical issues by looking at the switch, it has an internal circuit breaker, which has not tripped.
I am open to any and all suggestions of what to try as I’m not an electrical expert. In reading the manual, it says the next step is to replace the switch, which seems logical to me and I’ll order one from grizzly when they open on Tuesday. Grizzly is the manufacturer of this ShopFox, W1740 model.
Is there anyway to diagnose this problem myself?
Randy
Old 01-14-2024, 01:53 PM
Twice the size--half the man
Welcome aboard Randy. Glad to see ya, and hope to get to know ya.
First suggestion on anything that gets used on wood and electrical issues is to bust out the air compressor and blow everything out as best you can. During your ride home, it could have easily dislodged some ancient dust and gummed up the works.
ShopFox is a decent 'brand' as well. I don't know that Grizzly actually makes the tools so much as specs them, or if they're even related at all. It's been my experience that they're a bit better quality of chicom equipment. Nothing wrong with that necessarily. One advantage is that the switches, components, etc. are all readily available and much cheaper going through Amazon than ordering from the manufacturer or vendor.
If blowing it out doesn't work, pull the switch and check it out. It's likely very inexpensive and a good place to start the diagnosis.
Wade's Custom Kydex
Old 01-14-2024, 03:22 PM
Welcome to the site.
Sounds like the cord on the sander maybe bad, wiggle the cord at the bends and see if the sander starts.
bypass the switch and see if it starts.
what type of motor does it have?
Old 01-14-2024, 03:56 PM
...Sounds like the cord on the sander maybe bad, wiggle the cord at the bends and see if the sander starts.
bypass the switch and see if it starts...
Yup, start with the cord and work in...
Old 01-14-2024, 04:07 PM
Welcome .I think you have a good place to start Blow it out then start at plug and go from there . A Volt meter check will help find the loss .
Old 01-14-2024, 06:30 PM
Do I have a life?
Pull the switch out so you can access the connectors--when you do the next step be careful you don't touch the bare connectors on the switch or let them "short" against the housing. Wrap electrical tape around it if you have to. Plug it in, check for voltage at the switch "in" connector, turn it on, check for voltage at the switch "out" connector.
If there is voltage at the out (to motor) connector, it is something with the motor or connector at the motor. Possibly a start or run capacitor?
To check for a bad cap, with unit "on", spin the roller in the direction it should turn. If the unit starts, a cap is bad--make sure it doesn't bite you when it spins up.
HF 80 lunchbox w/tig
Old 01-14-2024, 07:35 PM
Ok, blew inside clean, reassembled the switch and housing. No obvious electrical problems. Non start continues.
Old 01-14-2024, 07:36 PM
No cord issues.
Old 01-14-2024, 07:40 PM
Main Motor: 1-1/2 HP, 115V, 60 Hz Feed Motor: 1/8 HP, 110V, 60 Hz Full-Load Amp Draw: 13.3A
Old 01-14-2024, 08:08 PM
Attached pic. Which wires correspond to your instructions?
