Old 06-09-2023, 01:29 PM
Default Enco Lathe, smoking deal
Picked up this Lathe on Craigslist last month.
The story is he was charging his laptop, the laptop started a fire and pretty much destroyed everything in the garage.
laptop was about 8 feet to the right of the lathe sitting just behind his tabletop mill, the mill was on a wooden bench the legs burned out and the mill crashed to the floor.
Also destroyed some type of laser engraver, Lincoln Mig welder, 3D printer, 3D resin printer, Mill,...... There was a Miller TIG welder 210 something, the face was pretty much melted he would have given that to me but I did not have anywhere to store it, figure for about $200 the TIG welder would have been repairable it went to the junk man.
His pictures of the lathe showed the belts were unaffected by the heat, did melt the plastic drum switch.
guessing about 250 degrees would not effect the metal parts on the lathe. I handed him his asking price $100.
At the same time there was a 3" vise on the floor, asked him how much he said $10, I handed him a twenty and said keep the change.
Name:	A 600x450.jpg
ID:	168090   Click image for larger version
Name:	B 600x450.jpg
ID:	168091   Click image for larger version
Name:	C P5180015.JPG
ID:	168092   Click image for larger version
Name:	D 600x450.jpg
ID:	168093   Click image for larger version
Name:	E P5290039.jpg
Old 06-09-2023, 01:31 PM
Scotts Scotts is offline
Yep that sucks on how all that happened, great deal though. did you get any more tooling?
Old 06-09-2023, 05:14 PM
You have quite a few hours of "clean up" ahead but it'll be worth it. :-)
...lew...
Old 06-09-2023, 06:58 PM
You sure you don't live in Tucson?
A month ago on a Monday morning, fire trucks arrived just down the block to put out a garage fire. The new owners had just moved in in the previous two days. A mobility scooter was being charged overnight and smoldered and finally caught fire around 5-6:00 AM, setting fire to the contents of the garage. The house was not damaged by the fire itself, but the smoke got in and damaged most of the house. Thank God nobody was hurt.
I talked to the guy a day later. He said he would salvage and keep his machine shop equipment.
On edit, that is a "smoking" deal.
Old 06-09-2023, 07:51 PM
Great deal!!!
Old 06-10-2023, 02:31 AM
I did get the 3 jaw and 4 jaw chucks, drill chuck that was in the tail-stock. figured just the two chucks are worth the $100,
He gave me the tool kit that goes with the lathe.,
most importantly it looks like I got all the gears and the jaws for the three jaw chuck.
ID:	168096   Click image for larger version
Old 06-10-2023, 02:43 AM
...lew...
That's what I was thinking, I miss judged the smell just cleaning may not get rid of the burnt smell.
Old 06-10-2023, 08:24 AM
Use a good primer sealer before topcoat . When wood use Kilz on the burn . I would think a sealer would do the same on the metal parts .
Old 06-10-2023, 09:28 AM
Not sure how well these work but a tarp over the lathe and an ozone generator inside may help with the smell. They aren't much money from the web.
Old 06-11-2023, 01:22 AM
You talked me into it i went out and purchased some Rust-oleum Primer, not happy it did not state sealer but good on metal.
did look at a can of Kilz stated sealer and odor blocker but stated only good on painted metal, a lot of new paints don't do well on metals so went with Rust-oleum.
