#31
I ordered a Manual.. The filter is already remotely located.. It's under the step.. I was asking more about experiences with certain brands and if you guys have a preference. I like housings with filters vs cannister.. I can then see if there is stuff it it vs cutting the can apart.
_________________ Jennifer If I defend myself I am attacked. My meaningless thoughts are showing me a meaningless world. My attack thoughts are attacking my invulnerability. I'd like to think of something smart, but I don't want to hurt myself. ![]() My google+ page DoALL 36" Another Johnson model J Project Lathe? Maybe..... 1958 SBL 13" Yeti Esseti Aka running welder on 3phase. https://www.shopfloortalk.com/forums...860#post766860 |
#32
Great progress yesterday..
Drained the transmission and pulled the sump screen and the inside is completely clean other than a little oil sludge on the bottom. Few little fuzzy on the magnet I ran through.. The oil filter housing turns out with galvanic corrosion and smutz that kept it from turning.. I welded on an 1 1/8" nut to the bottom and after applying a little heat to the alum to expand it some, it came apart just fine.. Absolutely clean inside the canister as well. I cleaned the threads on both and put it all back together.. Used some vaseline on the threads putting it on and off a few times and then wiped the vaseline off.. Wire brushed it by hand.. Put a little more vaseline on and put it all back together.. Looks like there was a flat o-ring that went on the very top of the holder but is missing.
#33
Those threaded canisters are a bitch. I'd leave the nut on it.
It looks like you got a good trans, nice and clean inside.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. BLM has proven to mean Buy Large Mansions The virtue is always a cover for the sin. That's the key to understanding the modern left. Whatever they're accusing you of doing, they are doing themselves but more enthusiastically. And that's definitely the story of Justin Trudeau. Tucker Carlson |
#34
I looked for some heavy wall square tubing with 1" id but could not locate any in the stash.. So the nut was the next best thing.. Had 1.5" and 1.125 castle nut.. Works really well.. Thanks drove it today for the first time.. These gauges work: oil pressure, Amps, Temp.. The other ones do nothing. I'd like to get gauges working.
#35
pulled off the front grill few days back..
Badly bent and the perforated screen was in front of the main unit. So straightened both out and fixed the heavy grill.. Then added a little bling. I also pulled off the valve cover to check out the lash..
#36
TA Arcmaster 185 w/tig/stick kit MillerMatic 252 w/3rd gen 30A MM140 w/o AS, w/CO2 Hobart (Miller) 625 plasma Hobart 250ci plasma Victor O/A (always ready, but bored) TA 95 lunchbox w/tig 45ACP Black Talons for those stubborn jobs... |
#37
Made me want to get on my IH shirt.. ![]() ![]()
#38
Tuesday I adjusted the valves..
I could not believe the head is flat on top or nearly so and the valve cover is flat with no grooves or channels to hole a gasket.. The gasket is completely flat too.. the 1978 Kabota uses a straight sided oring gasket.. A little weird.. I ended up using Ultrablack to hold it in place and seal it up. I adjusted the valves as per the manual.. I read 2 different specs.. 0.27 and 0.30.. Most of the valves were in the 0.60 range.. That was encouraging.. As no major valve reseccion of the valve nor burnt valves.. Of course burnt valves are very hard to tell other wise..
