Old 09-04-2006, 01:30 PM
Photomask's Avatar
Photomask Photomask is offline
Big Stone
Default Cable Slider
At the request of the Great and Powerful Oz, er, I mean Cutter.
I'm reposting so it can be moved easier.
I moved my old tombstone on top of a cabinet to save floor space.
I needed a better way to store cables without making them difficult to get to.
Space is at a premium...
I mounted a set of full extension ball bearing drawer slides on the side of the cabinet. I used 22in slides, because that's what I had available. It is critical that they be mounted absolutely parallel. Extend them out to get a longer frame of reference, within 1/16 should be more than adequate.
Next, I fabricated a simple square frame out of 1x1x1/8 inch angle. You could use about anything rigid depending on your scrap pile. The taller you make the frame, the less length leverage will have to work against the slides.
I mounted a couple of pieces of 2x1/4 flat bar 4-1/2 inches long for the cables to rest on and capped them with a couple of 2-1/4 inch disks from my scrap pile.
Name:	Slides Extended.jpg
ID:	15491   Click image for larger version
Name:	Slides Mounted.jpg
ID:	15492   Click image for larger version
Name:	Cable Rack 01.jpg
ID:	15493   Click image for larger version
Name:	Cable Rack 02.jpg
Old 09-04-2006, 01:37 PM
Photomask's Avatar
Big Stone
Default Round Two
Paint the frame your desired color.
I just happened to have some Miller Blue laying around.
Mount the frame to the slides, making absolutely sure you maintain parallelism.
I used SS #8 by 3/4 inch machine screws with nylock nuts.
Hang the cables and try it out.
It would probably work on a truck and could be modified to fit about anything.
The drawer slides are rated for 100lbs. In this application they would probabaly handle quite a bit more. If you need much more than that, put in a second, or even, third pair of drawer slides. Load capacity depends entirely on how many sets of slides you want to put in.
If you're wondering about the 2-1/4x3/16 inch disks...
They're punchouts, I get them from my great uncle during my visits to the Texas Panhandle.
I use them for just about everything...
I have been known to share....
Name:	Cable Rack No Cables.jpg
ID:	15496   Click image for larger version
Name:	Cable Slider Extended.jpg
ID:	15497   Click image for larger version
Name:	Cable Slider Retracted.jpg
ID:	15498   Click image for larger version
Old 09-04-2006, 02:23 PM
Project Manager Project Manager is offline
or Project Empress
Thank you.
Not "moved" but posted and linked.
Old 09-04-2006, 08:37 PM
madam X's Avatar
madam X madam X is offline
One Wonderful Lady!
Hmmmmmm . . . windchime . . . kayak anchor . . . weapon to throw at dogs who chase bikes . . . nail on trees to mark property lines . . . shims to elevate the back of puter keyboard . . . artsy funky pendant on a hemp cord . . . pie weights . . .
The possibilities are endless.
Rated M for MAGA
Old 09-04-2006, 09:52 PM
Lil Orphan Annie Eyes
Old 09-04-2006, 09:57 PM
TEK's Avatar
TEK TEK is offline
Line 'em up and plink 'em
-----DozerDan
Old 09-05-2006, 04:10 AM
Silverback's Avatar
Silverback Silverback is offline
OK, I'll ask... what's a punch out? Out of what?
I can see plenty of uses, but looking around I don't see what they came out of...
Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
Old 09-05-2006, 09:32 AM
Photomask's Avatar
Big Stone
My great uncle manufactures wire feeders, spools, rollers, etc, mostly for the powerline companies. A punchout is the slug that is "punched out" of a plate to make a hole for a bearing or shaft. Everytime I make it up there to visit, I go through his scrap piles in search of usable goodies. Buckets full of these punchouts are always available.
Old 09-05-2006, 09:34 AM
Photomask's Avatar
Big Stone
I would hate to be on the recieving end...
Old 09-05-2006, 01:37 PM
smitty7
Guest
Posts: n/a
Photo, you done good!
