Old 03-29-2013, 06:47 PM
Default Ah crap.Broken Cutoff lathe insert holder.
Well while working on the Mailbox hinge mechanism I happen to do the wrong thing and I broke my New (past fall) gift from Pixman..
I was so bummed.. I have had just about enough of working with Hydraulic cylinder rods..
What I should say is they are a unique material of what I can see are cast iron and then made into malleable iron surface hardened rods..
Surface hardened from 1/8" to 1/4".. Pixman was kind enough to show me which inserts to use with the hardened material but I still am learning..
On one of the pins I was cutting off I was getting a little to much vibration so figured I'd lower the rpms to the lowest setting without back gearing and within a second my beloved cutoff tool was completely ruined..
Took the insert and the nose completely off..
((((I made the cardinal mistake. With inserts I should have increased the speed and feed.. (Pixman reminded me of this)))
Anyhow, I fixed it today..
I tig welded it back together.. Yes, I'm not proud of the weld beads.. I was actually quite disappointed with the beads appearance but they certainly should hold.
I welded on some 2" bandsaw blade stock as the reinforcement...
I welded the broken tongue first then put the reinforcement piece on.
ID:	103714   Click image for larger version
ID:	103715   Click image for larger version
ID:	103716   Click image for larger version
ID:	103717   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-29-2013, 06:52 PM
Here you can see the fix and this should actually help to make it a little more ridged.. At least I keep telling myself that..
I got a chance to use it today and it worked just the same as before..
And,, Guess what.. I finished a project in record time...
ID:	103719   Click image for larger version
ID:	103720   Click image for larger version
ID:	103721   Click image for larger version
ID:	103722   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-29-2013, 09:53 PM
mtnkrake's Avatar
mtnkrake mtnkrake is offline
Nice fix.
Old 03-29-2013, 10:00 PM
Jen, that hydraulic ram or cylinder pin type of material is very nice free machining if you take the ram and lay it in a wood fire and cook it til the fire dies. Next morning it is great stuff to machine.
Old 03-30-2013, 03:15 AM
Yep, nice fix.
Old 03-30-2013, 04:13 AM
Thumbs up
A trash wood fire is much cheaper than replacing one of those tools.
edit: I forgot to mention how much of a neat repair you did.
Old 03-30-2013, 05:49 AM
OZWELDER's Avatar
OZWELDER OZWELDER is offline
Its the mark of a good tradie, that when a blue is made, you are able to repair it and move on.
tradie = trades person
blue = mistake or error
Good fix Jenn.
Oz
Ozwelder
Old 03-30-2013, 06:27 AM
That is a great idea about putting in the fire.. A good annealing will do wonders..
I actually only have a few of the rods.. I'm a little mad at myself since the guy who did the cylinder rebuilding is retiring this year and I only found out about the scrap rods a few years ago..
Everytime I go out that way I always check the scrap bin since they just give them away.. I've only gotten lucky twice..
Had it been 5 years ago I had 17 brush fires but now not much junk wood around..
Thanks all.
_________________
Jennifer
My google+ page
DoALL 36"
Old 03-30-2013, 09:03 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Jenn, nice repair.
As for junk wood find a place that gives away pallets, a friend of mine has been burning pallets for years in his outside wood burner to heat his home and shop. He used to cut them up with a Skilsaw and then burn them in an airtight stove in the house, until he got the outside one. He can put a full length runner in the stove. He built a pallet breaker that runs off the hydraulics off his tractor. He gets broken and damaged unbranded pallets from about a dozen places around the area.
The moral here is some places give them away instead of adding them into the dumpster.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 03-30-2013, 11:37 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
I was given a piece of round stock 1"X 8'..Said it was brake actuating rod for a RR car..Harder than satans heart..
Jen how about an "I" for ingenuity. Remember..it's not how bad you F up but how quick you recover..
