Old 12-12-2020, 06:24 PM
OldRedFord's Avatar
Kibble King
Default Honda four wheeler project
Got this Honda from my neighbor for $50. It's not 4x4. The model sticker on the frame says T_X 250. Can't make out the middle letter.
I've got new bearings to mount the rear axle back under it. Other tgen tgat not sure what else it needs. Would like to know for sure what model it is though.
Tim
Old 12-12-2020, 07:37 PM
Likely a TRX 250. Full list of models.
Old 12-12-2020, 10:56 PM
OldRedFord's Avatar
Kibble King
Thanks for that. Got me in the right direction. Seems to be a 2000's Honda Recon 250.
Tim
Old 12-12-2020, 11:37 PM
Sometimes amazing what stuff you can find on the net.
Old 12-13-2020, 08:32 PM
kbs2244 kbs2244 is offline
I believe the 250 was a 2-cycle engine
My sons had both a 200 and 250 ATC (3 wheelers)
The 200 was 4 cycle and much more reliable
The 250 was the temperamental hot rod
The quads came after the TV show
Old 12-14-2020, 01:32 AM
That will come in handy! There might be numbers on the steering head tube. MotorDoctor would know...
TA 95 lunchbox w/tig
Old 12-14-2020, 09:52 AM
MotorDoctor's Avatar
Karma Avenger
The VIN plate on Honda 4 wheelers is usually on a sticker on the frame near one of the front suspension arms. Sometimes it's stamped into the frame tube under the engine facing out near the stator cover. Once you have the VIN, you can give it to a Honda dealer and they can tell you exactly what you have. At least what it was when it left the factory.........
Old 12-14-2020, 08:46 PM
OldRedFord's Avatar
Kibble King
I'm amazed this thing will run.
After that I got a list of parts to get it useable.
Lost the one special bolt for the swimg arm bushing so that's the first thing.
Starter relay....its missing
Ignition switch...its broken
Banjo bolt to hook brake hose to master cylinder...missing
Ignition coil/plug wire. Need a new plug wire. Boot is cracked where it fits on the plug.
Choke lever assembly. Missing the screw to hold it on and a spring.
Seals for swing arm bushings.
Dust covers for bushings.
Bolt to mount shock to swing arm.
As of now I've got $200 invested including purchase.
Tim
Old 12-14-2020, 10:35 PM
It might need a heavier piece of string to hold the rear axle on, heck, you might even move up to twine, or cord instead of string for added strength.
Honda motors are pretty good little motors that seem to run for a long time.
Old 12-15-2020, 02:48 PM
Karma Avenger
The one thing Honda motors don't like (as well as all the rest), they don't like being run out of oil. I've seen dozens of them destroyed that way. The other method is putting the cartridge style oil filter in backwards. That'll get you some localized welding
